ᐅ Floor plan design for a single-family house on a hillside, with a separate apartment and a double garage
Created on: 15 Mar 2021 08:16
Andreas94
Good morning, dear forum members,
We received the first draft of our single-family house over the weekend and are initially very pleased 🙂
We would like to share the first sketches here to get feedback from experienced homebuilders.
A few notes:
Due to the slope of the plot, we will build with a basement. It will house a separate apartment / my wife’s naturopathic practice.
A home office on the ground floor or attic is essential as I regularly work from home (even before the pandemic).
We are currently planning a house for 3 children. Additional space could be created by expanding over the garage.
The heating system will be a ground-source heat pump. Our plot measures approximately 1200 m² (0.3 acres).
Regarding the cost calculation, I want to provide some information. We received the following estimates from the planner:
KfW 55 house
Residential building: 1,145.917 m³ (40,462 ft³) x €350/m³ = €401,070.95
Garage: 511.66 m³ (18,060 ft³) x €175/m³ = €89,541.55
Additional construction costs: €30,000
The calculated costs for the residential building do not include expenses for interior fittings. Owner’s contributions are also not included.
I look forward to your feedback on the floor plans.
Critical comments are explicitly welcome 🙂
Architekturplan: Einfamilienhaus mit Doppelgarage und Einliegerwohnung – Entwurf
Kellergeschoss-Grundriss: Küche/Essen/Wohnen, Diele, Treppenhaus, Hobbyraum, Dusche/WC
Architekturplan: Erdgeschoss-Grundriss mit Garage, Terrasse und Treppen; Schnitt 1-1.
Südwesten-Ansicht eines Hauses mit Treppe; Dachgeschoss-Grundriss darunter.
Vorschlag: moderne Wandtrenner mit Kamin, offener Wohn- und Essbereich, links Bauphase, rechts fertig.
Esszimmer mit langem Holztisch, grauen Stühlen und Fensterbank-Sitzfenster; Pendelleuchten.
Flächenberechnung: Dach 85,78 m²; Erdgeschoss 95,57 m²; Kellergeschoss 79 m², Ziel -10 m².
Andreas94
17 Mar 2021 15:03
??? How do you already know that? Logically, there can't have been any tendering yet, right?
What for the tendering?
This is now a small step back to the topic of finances.
We will subcontract the trades that we can't do ourselves to local companies in individual contracts.
11ant17 Mar 2021 15:21
A tender process is related to planning – the financial aspect only becomes relevant when it’s done without knowledge and experience – then it gets expensive.
Andreas94 schrieb:
Why the tender?
[...] We will subcontract the trades we cannot carry out ourselves to local companies through individual contracts.
The tender is done to know who you award the work to. Smart builders never exclude their architect’s general contractor (GC) from participating.
17 Mar 2021 15:44
Andreas94 schrieb:
The requirement for the basement is simply that we can include a second dwelling unit for BAFA subsidies in the KFW55 house.
Actually, only a practice space is needed. But to qualify for subsidies, it is declared as a separate apartment and then converted 🙄
Andreas94 schrieb:
I haven't read anything contradicting the idea of renaming a "separate apartment" to a "practice" afterward..
Andreas94 schrieb:
Once this is done afterward, no parking spaces need to be designated.
And that also has the nice advantage that you don’t have to build any parking spots.
Myrna_Loy
17 Mar 2021 16:05
Actually, only a practice space is needed. However, to qualify for subsidies, it is declared as a secondary apartment and then converted 🙄
And that has the additional advantage that you don’t have to build any parking spaces.
Yes and no. We recently dealt with parking space requirements when a practice temporarily expanded its rooms due to COVID-19 by using a condominium. We had to provide proof of parking spaces according to the updated use classification with the application. That meant 3 spaces that could not be used for other purposes.
I wouldn’t rely on verbal assurances like “it’s all easy” for planning.
Andreas94
17 Mar 2021 16:15
Actually, only a practice room is needed. But in order to receive subsidies, it is declared as a separate apartment and then converted 🙄
And that also has the convenient advantage that you don’t have to build any parking spaces.
I’m not sure if you mean that sarcastically? 🙂
Andreas94
17 Mar 2021 16:18
Myrna_Loy schrieb:
Yes and no. We recently dealt with parking space requirements when a clinic temporarily expanded its rooms by using a condominium due to COVID-19. We had to demonstrate parking spaces according to the updated usage key with the application. That was 3 spaces, which could not be used for other purposes.
I wouldn’t plan based on verbal assurances like "everything’s easy."
The authorities always act according to the current legal situation.
We were informed in writing that no additional parking spaces have to be designated at the moment.
In our specific case, the parking space in front of the garage is sufficient.
How it will look in 5…years, of course, no one can say.
Due to the unwanted large-scale surface sealing, I hope not to have to designate more parking spaces by then.
But that concerns the future and is only speculation at this point.
