Hi,
How noticeable is the difference in thickness of the luxury vinyl flooring between 6.5mm (0.26 inches) and 9.3mm (0.37 inches) when used with underfloor heating?
For example, if I take Haro floors here, the thermal resistance is between 0.046 and 0.063 m²K/W. These are all theoretical values, but would the difference actually be noticeable?
Nordlys schrieb:
It is more important to avoid any air gaps between the subfloor and the covering, so glue it down. The rest doesn’t really matter. We are actually planning to install the flooring as a floating floor because we want the impact sound insulation and don’t want to feel like walking directly on the screed 😉
nordanney16 Mar 2021 07:23Valerion schrieb:
We are actually planning to install it as a floating floor because we want impact sound insulation and do not want to have the feeling of walking directly on the screed. You won’t notice any difference between the two flooring methods.
Apart from that, you’ll hardly notice any difference between glued down and floating installation—except that floating floors always sound somewhat hollow and the walking noise is higher. In my opinion, floating installation is only a makeshift solution.
pagoni202016 Mar 2021 20:56I am not familiar with these thin design floors, but we have parquet flooring about 14mm (0.55 inches) thick, which wears very well even when installed as a floating floor. At least with parquet, I would do it the same way again because the glued-down floors I have experienced felt too "hard" for my liking.
JürgenJosef24 Mar 2021 21:54With underfloor heating, the air between the heating elements should act as an insulator. Impact sound insulation is important. Therefore, the best solution is to glue down the design floor.
