we are currently building our single-family house with a general contractor. Our quote includes electronic roller shutters and venetian blinds. The offer also includes one switch planned for each roller shutter or venetian blind. However, we are not entirely satisfied because there is no option to lower all the roller shutters and venetian blinds at once. Currently, I see the following solutions:
1) One central switch per floor (basement, ground floor, upper floor) that lowers all the roller shutters/venetian blinds on that level. According to the electrician, this is complicated to implement and quite expensive (about 1000 euros per switch plus wiring).
2) Each roller shutter/venetian blind is equipped with an actuator (is that the correct term?), which we can control wirelessly. In other words, everything operates with switches, but I have the option to send a wireless signal to all roller shutters so they go down or up together.
3) Electric wireless drives are used (e.g., Somfy Rs 100 io). Then no wired switches would be needed for the drives. However, I would have wireless switches stuck to the whole wall. Is that really practical?
I’m sure there are clever solutions I haven’t thought of… Can you help me?
haydee schrieb:
I don’t understand why you have an entire wall full at point 3. There is a central switch, for example in the hallway, and you can install individual switches at the windows to operate each roller shutter separately.Maybe I didn’t explain myself clearly. Yes, there aren’t any more switches, but these switches are stick-on types (at least with Somfy), which look different from the others, and I can already imagine the kids pulling those switches off.
