ᐅ Walk-in shower: What is the recommended width for the entrance?
Created on: 10 Mar 2021 12:22
micric3
Hello forum,
once again, we need your collective expertise. Our shower measures 1.40 x 1 meter (4 ft 7 in x 3 ft 3 in). The entrance is planned on the 1.40 meter (4 ft 7 in) long side. Since the quote from our plumber for a glass panel/door seems too expensive, we are wondering if a walk-in shower would be enough?
We understand that some splashing may occur. However, we have sufficient slope for drainage, and a small towel in front should be enough.
How wide should the shower entrance be? 70 cm (28 in) ↔ 70 cm (28 in), or would 80 cm (31 in) – 60 cm (24 in) be better? Currently, we have an old corner shower with a 40 cm (16 in) wide entrance.
Good luck
m
Good luck
m
Alessandro schrieb:
A 60cm (24 inch) passage is entirely sufficient for average people.I might be a bit crazy, but I find 65cm (26 inches) comfortable enough :-)https://www.instagram.com/11antgmxde/
pagoni202011 Mar 2021 12:3911ant schrieb:
I might be crazy, but 65 is comfortable enough for me 🙂Spoiled guy……pagoni2020 schrieb:
Spoiled guy......I just hang my aura with the bathrobe on the hook, and the body alone then fits easily through the little door ;-)https://www.instagram.com/11antgmxde/
Nordlys schrieb:
...and if you want to cleanse the aura?....... then I will write a malicious comment here about a hack ;-)https://www.instagram.com/11antgmxde/
