ᐅ Selection of bathroom tiles (size, layout, height)
Created on: 22 Jan 2021 17:40
F
Forsberg21
I bought a condominium last year that is currently under construction through a developer, and in a few weeks I have the selection appointment. The apartment will be rented out initially.
Attached is the bathroom layout. According to the building specifications, I can choose tiles up to 60 € including VAT (about $65) and roughly 60% of the bathroom wall area may be tiled. Otherwise, I would need to pay an additional fee. However, I’m not sure about the tile size, how high they should be installed, or the tile pattern to use. I would appreciate any advice. Unfortunately, the tile showrooms are all currently closed, so I can’t get any inspiration there.
At the moment, I’m considering dark floor tiles and light (cream/beige) ceramic wall tiles, sized either 30 x 60 cm (12 x 24 inches) or 30 x 90 cm (12 x 36 inches). The tiled area should be about 1.20 m high (4 feet), but the long left wall (4.12 m / 13.5 feet) only needs tiling up to the baseboard height. The shower area should, of course, be tiled up to the ceiling. For the area with the washing machine and dryer, I’m unsure whether it makes sense to tile all the way up. What do you think?
What tile size would you recommend for the walls in this narrow room? Half-bond (staggered) pattern? Third-bond pattern?
What size would be best for the floor tiles? Would it make more sense to lay rectangular floor tiles crosswise in this case, or should they always be aligned parallel to the wall tiles?
The hallway and storage room will also be tiled. Is there anything important I should consider for these areas?
Thanks in advance.
I hope it’s okay to share a plan section here. There is no information about the creator within the plan section.
Regards,
Robert
2D-Grundriss-eines-Hauses-mit-Bad-Diele-und-Schlafzimmer
pagoni2020
2 Mar 2021 21:15
Take a look at EmilCeramica Tracce Taupe.
We have it here in stock, both wall and floor tiles in 60cm x 60cm (24in x 24in).
Great tile.
2 Mar 2021 21:20
Ivory.... WOW! 😀
Beige tiles arranged in a vertical row with elongated hexagonal shapes, resembling a fence.
F
Forsberg21
3 Mar 2021 08:07
Great tile.
Thanks. The catalog available for download there is excellent. Besides Taupe, I also really like the Ivory color. However, I assume that the developer or the tile supplier they have contracted won't be able to provide me with these tiles.
pagoni2020
3 Mar 2021 08:08
Forsberg21 schrieb:
Thanks. The catalog available for download there is great. Besides taupe, I also really like the ivory color. However, I assume that the developer or the tile supplier they hired won’t provide these tiles for me.
Why not?
This brand is available in every well-stocked tile store.
3 Mar 2021 09:04
Forsberg21 schrieb:
Thank you. The catalog available for download there is great. Besides taupe, I also really like the color ivory. However, I assume that the developer or the contracted tile supplier won’t be able to provide me with these tiles.
The tiler can usually get almost any tiles. He always has 2-3 wholesalers he sources from.
bauenmk20203 Mar 2021 09:05
You can also try searching for "Deutsche Steinzeug Showroom".
