ᐅ Experience with Quality Differences Between IKEA Platsa and PAX Systems?
Created on: 27 Feb 2021 19:05
bauenmk2020
bauenmk202027 Feb 2021 19:05
we have a wall in the hallway about 190cm (75 inches) long and 2.58m (8 ft 5 in) high where I am planning a wardrobe. In the initial drafts, I planned this Pax wardrobe with sliding doors, next to which there is a bench (Besta system). Above that, there are also Besta wall cabinets.
Now I have seen that the Platsa system also offers a good option to combine this and it seems easier to assemble. However, I am wondering if the quality (long-term durability; "feel/texture") is sufficiently good?
Unfortunately, I cannot directly compare these two systems at the moment – has anyone already compared both systems and has experience with where exactly the differences between Pax and Platsa are?
hampshire
27 Feb 2021 22:56
PAX is very simple in its construction, highly versatile in interior design, and offers a good price-quality ratio. I find Platsa to be significantly less premium.
Bookstar
27 Feb 2021 22:59
Jo and Besta are also much cheaper junk compared to PAX. You can tell by the weight and the use of plastic instead of cast metal mounting parts.
Tolentino28 Feb 2021 00:11
Regarding quality in comparison, I cannot say anything since I do not own Platsa yet.
In general, looking at the selection, Platsa offers more cabinet size options, allowing for better room customization. PAX, on the other hand, provides a much wider range of configuration variants.
yellow_ms
28 Feb 2021 13:52
As an idea: I created a similar solution in the hallway, combining PAX with METOD. METOD wall cabinets were extended with legs to form the bench, with METOD wall cabinets above. The niche was lined with side panels. The PAX unit on the right is 600mm (24 inches) deep; I had to make it narrower towards the left because the front door is located there.
White built-in closet with black open niche and shoe rack below.
bauenmk202028 Feb 2021 18:06
yellow_ms schrieb:
As an idea: I created a similar solution in the hallway, combining PAX with METOD. METOD wall cabinets were extended with legs to serve as a bench, above that are more METOD wall cabinets, and the niche was lined with side panels. The PAX unit on the right has a depth of 600mm (24 inches); on the left, I had to go narrower because the front door is located there.
Is the METOD on the far left? What depth does it have, and can winter coats fit on hangers there?
Otherwise, I find METOD clever because of the legs and the matching plinth/kickboard.
