ᐅ Retaining Higher-Level Neighboring Properties: L-Shaped Retaining Walls and Tips
Created on: 27 Feb 2021 14:31
jaenno1
jaenno1
27 Feb 2021 14:31
I need your expertise. Due to the new elevation of our new build, I have to retain neighboring properties that are higher. The required retaining height would be 1-1.5 m (3.3-5 feet).
My first choice was concrete retaining walls (L-shaped blocks), but I cannot install the footings pointing towards the neighbors, as this would significantly encroach on their land.
Do you have any ideas, tips, or alternatives for me?
jaenno1
I
icandoit
27 Feb 2021 15:35
Planter troughs if you have enough space.
What exactly do you want to secure? The house is usually at least 3 m (10 feet) away.
Please upload a plan or a sketch.
Is the new building already constructed?
HilfeHilfe
27 Feb 2021 15:47
Doesn't the neighbor have to secure their slope? Or do you have to do it towards your neighbor?
AxelH.27 Feb 2021 17:21
jaenno1 schrieb:
My first choice would have been L-shaped concrete blocks, but I can't install the footings facing the neighbors, otherwise I would significantly encroach on their properties.
For this purpose, there are also L-shaped blocks with the footings on the opposite side. However, in my experience, these are considerably more expensive than the standard models.
27 Feb 2021 18:21
HilfeHilfe schrieb:
Doesn't the neighbor have to secure their slope? Or do you need to secure the slope down to your neighbor?
Well, only if they have changed the level.
11ant27 Feb 2021 23:27
AxelH. schrieb:
There are also L-shaped blocks designed for this purpose, which have the feet on the other side.
You have me surprised ;-)
