ᐅ Air source heat pump – is ice formation normal?
Created on: 14 Feb 2021 11:18
Andre77
Andre77
14 Feb 2021 11:18
Hey,
is it normal to have this much ice?
Outdoor air conditioning unit with heavy ice buildup, icicles, and frozen water on gravel ground.
Outdoor air conditioning unit dripping ice water onto a stone surface with gravel.
berny14 Feb 2021 11:34
At night, -15°C (5°F) is normal if this is an "infiltration drainage," meaning there is no separate drainage channel for the meltwater.
Andre77
14 Feb 2021 11:49
Exactly, there is no separate drainage... it simply goes down into the splash guard...
HilfeHilfe
14 Feb 2021 11:55
Same here. Guys, we have -10 to -15 degrees Celsius (14 to 5 degrees Fahrenheit) at night, and during the day we go ice skating on the frozen lakes...
Bookstar
14 Feb 2021 11:59
I will check on that, but as long as it doesn’t affect the functionality, it’s not a problem.
bernie
16 Feb 2021 10:34
Andre77 schrieb:
Exactly, there is no separate drain... it just runs down into the splash guard...
Completely normal, with our neighbors (we don’t have an air source heat pump) it also currently looks like this without a dedicated drain.
