ᐅ Installing floor-to-ceiling double windows with internal blinds—any experience?
Created on: 12 Feb 2021 12:24
chewbacca123
chewbacca12312 Feb 2021 12:24
Hello everyone, our floor-to-ceiling south-facing windows have external roller shutters. They work quite well to keep out the heat in summer, but we are now considering adding internal blinds. The idea is to be able to reduce sunlight during strong winter sun without making the room completely dark. Does anyone have experience with this?
Is it even possible to install blinds on the large windows when there is a roller shutter box above? Do you think mounting them inside the window frame is feasible – probably not, right? Because of the thickness of the blind slats.
What do you think about wooden blinds? I recently saw an advertisement online, and they looked really nice.
Thanks a lot and best regards
Interior view: dining area with large windows and roller shutters, wooden floor, table and chairs.
White double door with horizontal roller shutters, view into bright interior, wooden floor.
I
icandoit
12 Feb 2021 12:31
You just shouldn’t lower the blinds too much during winter. Only where the sun really causes discomfort.
chewbacca12312 Feb 2021 12:35
icandoit schrieb:
You just shouldn’t lower the blinds too much in winter. And only where the sun really causes glare.
That’s not the point, we definitely want blinds.
There is a glass-covered terrace under the windows – the glass panels sometimes cause glare when sitting at the dining table. That’s also why we want blinds.
pagoni2020
12 Feb 2021 13:17
For example, Rollo Rieper offers interior blinds that can be adjusted with a rotary knob, so you don’t have to deal with annoying cords. We have two of these in the bathroom, and I really like them. Maybe they will suit your needs. However, similar products are probably available from other manufacturers as well.
Steffi33
12 Feb 2021 13:58
This is very easy with these plastic clips… we have them on all our windows, including the patio doors. For larger windows, you might want to use more than two clips.
Window with white horizontal blinds; cords hanging down, view outside to a building.
Close-up of a white door lock clip on a smooth surface.
chewbacca12312 Feb 2021 14:33
Steffi33 schrieb:
This is really easy with these plastic clips.. we used them on all our windows.. also on the patio doors. For larger windows, you might want to use more than two clips.
That looks really great, thanks. But doesn’t that damage the window seal over time?
