ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
halmi
10 Feb 2021 13:53
I don’t quite get it either. The running pattern looks flawless, the pauses you’re referring to are defrost cycles...
What puzzles me more is why it stops heating at the end. Do you have any shutdown processes like p0_pause or something similar in the log?
Bookstar
10 Feb 2021 13:58
halmi schrieb:
I don't quite get it either. The operating pattern looks perfect; the pauses you're referring to are defrost cycles...
What surprises me more is why it stops heating at the end. Do you have any shutdown processes like p0_pause or similar in the log?
Where do you see that it stops? One thing is the defrost cycles, and at the other end, it reached the target return temperature plus hysteresis and then switches off.
halmi
10 Feb 2021 14:02
Even if your modulating pump is much too large, it should never shut off at around -5°C (23°F). The hysteresis looks like around 2K, right?
Bookstar
10 Feb 2021 14:10
It is set at 1.5k.
halmi
10 Feb 2021 14:16
Could you please upload a .csv file here?
Alessandro
10 Feb 2021 14:31
Zaba12 schrieb:
The breaks are really way too short for such a long runtime.
What causes the return flow to drop so quickly?
It's the same for me. I don’t know why either...
Within one hour, the return flow drops by 3°C (5.4°F).
