Hello, our house has a gas boiler that supplies two heating circuits: radiators in the basement and underfloor heating on the ground floor and first floor. I have a converted office room in the basement (about 18m2 (194 square feet)) — the basement is about 50% below ground level. There is a radiator installed in this room. The room gets warm, but the tiled floor remains quite cold. My question: would it be possible (or advisable) to install underfloor heating here afterward? Or are there other suggestions for dealing with cold floors in the basement? Thanks and best regards, ashley
pagoni2020 schrieb:
There is ultra-thin insulation material, and you could lay parquet flooring on top of that. Thanks for the tips. So, a first step would be to add to the floor. Can I just lay insulation material on the existing tiles and then install the parquet? Would I need to install a vapor barrier or something similar?
pagoni2020 schrieb:
You could, for example, install an infrared panel on the ceiling; What output would such an infrared heater need to have (as mentioned: insulated basement room, about 20 m2 (215 sq ft), about 2.20 m (7.2 ft) ceiling height)?
johnmanfred schrieb:
But we are talking about over 200 square meters here In my case, it’s about 20 m2 (215 sq ft)...
johnmanfred28 Jan 2021 18:15ashley schrieb:
For me, it's about 20m² (215 sq ft)Yes, I just wanted to emphasize that it also depends on the specific conditions.
