Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Alessandro18 Jan 2021 10:26But what does the nominal flow rate actually indicate?
Your heat pump modulates, which means the flow rate is constantly changing.
Alessandro schrieb:
But what does the nominal flow rate really indicate?
Your heat pump modulates, which means the flow rate is constantly changing.No, it is not a modulating heat pump.A
Alessandro18 Jan 2021 11:15Then you need to adjust the compressor capacity to match your house or your heating load in order to reach the nominal volume flow.
However, I think you have to go to the "expert level" or "technician level" in the menu for that.
tomtom79 schrieb:
Have you started a thread in the other forum?Yes, I have. No response for 2 weeks.Similar topics
