ᐅ Dimpled membrane not sealed
Created on: 14 Jan 2021 07:21
Dude2000
Hello, we have the opportunity to buy a house that is still under construction. It appears that a section of the dimpled membrane around the foundation is missing. Is this a significant problem?
Dude2000
15 Jan 2021 11:19
What would be the worst consequences if the vapor barrier is missing? I will bring this up soon.
I
icandoit
15 Jan 2021 13:03
Moisture penetrates the wall/insulation.
T_im_Norden
15 Jan 2021 13:42
The dimple membrane protects against mechanical damage and directs water away.
The actual basement wall and insulation should be waterproof anyway.
Dude2000
15 Jan 2021 13:47
Would be without a basement
I
icandoit
15 Jan 2021 13:58
T_im_Norden schrieb:
The dimpled membrane protects against mechanical damage and channels water away.
into the probably non-existent drainage. 😉
I
icandoit
15 Jan 2021 14:03
Nothing will happen at first. But over time, moisture spots will develop because the water is not being drained away. Before your landscaper fills in the area, make sure to have the gap properly closed. The already installed area clearly needs corrective work.
