I am sharing the floor plan as we have developed it. Perhaps there are some suggestions?
The dimensions are interior room sizes, with a wall thickness of 10 cm (4 inches) assumed. Depending on the actual wall thickness, adjustments will be necessary.
Plot size: 1200 sqm (12,917 sq ft)
Slope: no
Floor area ratio / plot ratio: unknown, but not important
Building permit / planning permission, building line and boundary: there is no development plan; the new house will stand where our current house is (only the distance to the neighbor must be increased to 3 m (10 feet)), which according to the responsible building authority is no problem
Edge development: no
Number of parking spaces: garages already exist and will remain
Number of floors: bungalow, single story
Roof type: gable or hip roof
Style?
Orientation: roof facing east-west
Other constraints: the plot is only about 16 m (52 feet) wide, so the house must not be wider than about 10 m (33 feet) in this direction
Homeowners’ requirements
Style, roof type, building type: bungalow, preferably gable roof
Basement, floors: no basement, only 1 floor, storage room in the attic
Number of occupants, age: 2 persons, 55 and 58
Space needs on the ground floor: about 100 sqm (1,076 sq ft)
Office: family use or home office: no
Overnight guests per year: 2 grandchildren occasionally, father occasionally
Open or closed layout?
Conservative or modern construction: rather conservative
Open kitchen, cooking island: open kitchen
Number of dining places: 4
Fireplace: yes, definitely
Music/sound system wall: no
Garage, carport: already existing
Utility garden, greenhouse: garden already established
Designed by:
- Do-It-Yourself, created based on various templates
What do you like most? Why?: large window front on the south side with direct access to the garden
What do you not like? Why?
- Corner in the hallway between utility room and bedroom, but the hallway should remain large to avoid bumping into each other and to have enough space for motorbike gear,
- I would prefer the fireplace positioned more in the corner between kitchen and living area, but that conflicts with neighbor distance regulations and emissions protection
Price estimate according to architect/planner: initial offers are around €190,000 for about 110 sqm (1,184 sq ft), but changes are still needed
Personal price limit for the house, including fittings: should not exceed €200,000 plus additional construction costs; equipment is already taken care of
Preferred heating system: gas condensing boiler, since gas supply is already connected
If you had to give up anything, which details/expansions
- Could you give up: nothing
- Cannot give up: underfloor heating, large window front, fireplace
Why did the design turn out as it is?
All wishes were implemented as far as possible
Is there anything that doesn’t work at all? Any room for improvement? What would you do differently? Where could it be optimized?
Slope: no
Style?
Designed by:
motorradsilke16 Dec 2020 18:16I’m grateful for any tips and will definitely reconsider your suggestions.
The “guest room” isn’t really a guest room; it’s my husband’s room, where he spends a considerable amount of time each day.
We just don’t want any walk-through rooms, especially not going through the bedroom to get to the bathroom.
Do you consider a utility room of around 10 square meters (about 108 square feet) to be small? My idea is to store supplies there alongside the heating system, washing machine, and dryer—I’ve already planned shelves for this. There will still be plenty of space in the middle to dry laundry or motorcycle gear if needed. And of course, I wouldn’t put clean laundry on the floor.
In our house, the utility room is the warmest room and can also be damp when doing laundry, so no food should be stored there.
The utility room is used for the washing machine and cleaning, so I would be concerned about the wall paint. My idea is to use the hallway for changing clothes and a shower area for drying and cleaning (with a drain, tiled floor, and handheld shower), which seems more logical.
The ideal would be a guest shower 1.5 x 1.5 meters (5 x 5 feet), where guests can go directly in, undress, hang clothes, and clean up, with mats placed along the path.
motorradsilke16 Dec 2020 20:05Nida35a schrieb:
For us, the utility room is the warmest room in the house and also humid when doing laundry, so no food is stored there. The utility room is for damp laundry and cleaning, so I would be concerned about the wall paint. My idea is a hallway for changing clothes, and a shower area for drying and cleaning (drain, tiled, handheld shower), which seems more logical.
The dream would be a guest shower 1.5 x 1.5 m (5 x 5 ft) where you can enter, change, hang clothes to dry, and clean, with cloths laid out on the floor to protect the route.Where do you store food then?
So is it important that the utility room also has temperature control?
