Good morning everyone,
I wanted to ask what your house’s electricity consumption is at night when everything is quiet and sleeping, so what is running continuously?
We have a newly built house, moved in summer 2019. Our building services include underfloor heating (air-to-water heat pump), controlled mechanical ventilation (runs at full power 3 times a day for 2 hours each, then reduced), a photovoltaic system, and otherwise the usual nighttime appliances (phone charger plugged into USB outlet, e-bikes charging occasionally, 2 TVs on standby, Alexas on standby, etc.).
At night, we have a continuous consumption of about 232W (with ventilation running at reduced power and when the heat pump is not producing). I can see this in the app for the photovoltaic system. From 0:00 to 6:30 a.m. we consume about 2.8 kWh.
How about you?
How about you?
Andre77 schrieb:
@halmi
I’m pretty happy with my current photovoltaic yield of just under 200 kWh for this month.Systems and especially location play a big role. At the beginning of December, in Munich you probably wouldn’t have generated a single watt on your photovoltaic system for about a week because of the snow, right? Here it was 3-4 days. The snow just stays on the panels even if it only snows for 5 hours.S
Stefan89016 Dec 2020 16:32Zaba12 schrieb:
Oh, by the way, December 21 is the winter solstice.
Basically a photovoltaic holiday 😎Then things will finally start looking up again 😀@Zaba12 Have the data from the first half of the year been entered into the Kostal portal? They are still missing for me.
Stefan890 schrieb:
Things are finally looking up again 😀
@Zaba12 Have the data for the first half of the year been updated in the Kostal portal? They're still missing for me. I can’t say for sure, my smart meter was only installed with the storage system at the beginning of May. Maybe that’s the reason. But yes, I only see everything complete from June 1st onward.
Stefan890 schrieb:
Then things are finally looking up again 😀
@Zaba12 Have the data from the first half of the year been updated in the Kostal portal? They are still missing for me. For me, everything before June is missing as well. But the old Piko portal is somehow still online. So maybe it’s still in progress...
