ᐅ Should you paint or wallpaper lime-cement plaster?
Created on: 10 Nov 2017 17:07
E
expose
I have lime-cement plaster throughout the entire house and want to start by painting everything white, possibly adding some accents after moving in.
The idea is simply to paint everything white first or maybe use wallpaper.
What have you done with your lime-cement plaster? Is it worth using silicate paint, or is the difference in indoor climate compared to an emulsion paint rather small? What should I pay attention to?
Does anyone perhaps have experience with wallpapers?
Many thanks to you all
truce19 Nov 2020 23:06
kinderpingui schrieb:
How was your base coat treated before painting? Was anything applied over the base render? Did you just fill and sand, and if so, with what material?
Hello Kinderpingui.
Unfortunately, this was some time ago, but here are brief answers to your questions:
  • Before painting, only a quartz primer was sprayed on using a standard Gloria spray pump.
  • The base render was simply "scraped off" by the plasterers at the end, resulting in a very light texture. We didn’t want it smooth. This also prevents visible "problem areas," as they are less noticeable with this texture.
kinderpingui
21 Nov 2020 07:36
truce schrieb:
Hello Kinderpingui.
Although some time has passed, here are brief answers to your questions:
  • Before painting, only quartz primer was sprayed on using a standard Gloria spray pump.
  • The base plaster was simply "scratched down" by the plasterers at the end of application to create a very slight texture. We did not want a smooth finish. This also helps to hide any "problem areas" since they are less noticeable there.
Ok. Thank you for the reply.
Was your base plaster applied so smoothly that there were no voids or bulging areas at all? How did you fill any voids?
truce21 Nov 2020 08:02
The base plaster, as far as I can remember, was also the final surface.
After a certain drying time, it was simply floated with a trowel and some water.
Just try searching for "lime cement plaster floating" to see what I mean.
I’m not sure what "Lunker" refers to, but if you mean dents or holes, we haven’t noticed any so far.
Also, no bulging areas—at least not under normal lighting conditions.
The advantage of this floating technique is that it reduces the visibility of unevenness compared to completely smooth wall surfaces.
Winniefred23 Nov 2020 18:18
We recently replastered the first room ourselves, using a lime-cement plaster. After it set, we smoothed it thoroughly with a float, then did some rough filling, applied a primer, and finally wallpapered. Our daughter wanted a feature wallpaper, and the rest of the walls were painted yellow, so we put up the feature wallpaper and applied fine woodchip wallpaper on the other walls before painting them with ordinary emulsion paint. We didn’t do extensive filling since the floating already gave a pretty good finish. We are happy with the result and plan to do the same for the next room.
kinderpingui
24 Nov 2020 21:52
Winniefred schrieb:
We recently replastered the first room ourselves using a lime-cement plaster. After it started to set, we thoroughly smoothed it with a trowel, then roughly skim-coated it, primed, and finally wallpapered. Our daughter wanted a feature wallpaper, and the rest of the walls were painted yellow, so we applied the feature wallpaper and used a fine textured cellulose wallpaper (Raufaser) on the other walls before painting them with a standard dispersion paint. We didn’t do extensive filling since the smoothing was already quite good from the troweling. We are happy with the result and plan to do the same approach for the next room.
Thank you. What exactly did you use for the rough skim coating? A special filler for lime-cement plaster or just the base plaster?
Winniefred24 Nov 2020 22:24
I need to check again, but it was definitely a standard wall and ceiling filler from Sakret.
