ᐅ Should the EIFS insulation on the gable side extension be left in place or removed?
Created on: 15 Nov 2020 19:42
Hendrik M.H
Hendrik M.15 Nov 2020 19:42Hello everyone,
I’d like to ask for your advice.
We have a cozy single-family home. We also have a little girl, and then triplets came along 🙂
Now the house is too small, and we want to build an extension.
The plan (by now) is to add a gable-end extension of 5 m (16 feet).
The house was built in 2006 and has an external thermal insulation composite system (ETICS) with 14 cm (5.5 inches) of insulation.
Our architect asked if we want to keep the existing ETICS on the gable end. We could also run electrical and heating pipes inside the insulation at the same time.
The downside, of course, is that the joints between the old and the new part would be about 60 cm (24 inches) deep.
Also, it somehow feels like a bit of a quick fix to just leave the old ETICS in place.
However, the architect also said it could help to reduce possible movements between the buildings or settling issues.
What is your opinion on this?
Hendrik
Hendrik
You seem a bit confused: I almost pointed you to your own thread: https://www.hausbau-forum.de/threads/neubau-nach-drillingsgeburt-freue-mich-auf-eure-ideen.28849/page-6#post-285181 – there either you appear twice (probably once on desktop and once on smartphone) or there is someone with the same name having the same issue (?) – in any case, at that time I recommended a gable-side extension, but then the exterior wall would be a three-layer construction???
Hendrik M. schrieb:Off the top of my head: changing the architect, how is that supposed to reduce settlements in the external thermal insulation composite system (ETICS) / insulated render system? Why would you still need it on an interior wall, and why does he want to chase it there?
The architect also said that it would be helpful to mitigate potential relative building movements or settlements.
Hendrik M.15 Nov 2020 21:48Wow, good memory. It seems your nickname isn’t a coincidence 😉
Actually, these were our first considerations two years ago. We then went to an architect and had a real crash landing. A few thousand euros later, he told us that we should move out for six months during the renovation and his original cost estimate was off by more than a factor of two. After that, we simply lost motivation, stuck our heads in the sand like an ostrich, and waited.
Now we want to make a second attempt with a different architect, this time a local one.
So, I gather that we should better remove the insulation.
And you would rather recommend chasing (cutting grooves) in the new masonry interior wall, which will adjoin the current exterior wall?
Hendrik M. schrieb:
Wow, good memory. So you are consistent with yourself ;-) and the house is as shown in the linked thread? (that would imply a three-layer construction of the exterior wall – clarify the contradictory information, preferably from the building file).
Hendrik M. schrieb:
Now we want to start a second attempt with a different, this time local architect. My first choice would be the architect who built the house.
Hendrik M. schrieb:
So I take it that we should remove the insulation.
And you would rather recommend chasing the channels in the new masonry interior wall, which connects to the current exterior wall? The insulation on the interior wall doesn’t make sense. What should be installed where needs to be discussed in more detail. Please add the as-built plans including the site plan with the building envelope here in the thread.
Hendrik M.17 Nov 2020 09:14Hello,
here is the requested information.
The current exterior wall consists of the brick, insulation, and a layer of plaster and is about 40cm (16 inches) thick. It is not clad or otherwise covered.
I am not exactly sure what you mean by building envelope. Zoning plan / development plan? (single-story, eaves height 4.5m (15 feet), floor area ratio / site coverage 0.4; with garage etc. 0.6). I can provide more details if needed.
I am unable to upload .pdf files here. If it helps, I can convert the zoning plan to images.
For your information:
The 3m (10 feet) boundary line is also shown in the "existing building on plot" section.
Hendrik M. schrieb:
I’m not sure exactly what you mean by building envelope. Do you mean the zoning plan? (single-storey, eaves height 4.5m (15 feet), floor area ratio/site coverage 0.4; with garage etc. 0.6). I am happy to provide more details here. [...] For your information:
For "existing building on lot," I also marked the 3m (10 feet) setback boundary. Only that these are by no means always – typically even mostly not – identical to the so-called "building envelope," which is the area of the lot where main buildings may be constructed.
Hendrik M. schrieb:
I’m unable to upload .pdf files here. If it helps, I can convert the zoning plan into images. I can usually work well with either format, happy to receive by email via gmx (de) using my member name.
Hendrik M. schrieb:
The current exterior wall consists of masonry, insulation, and a plaster finish. It is about 40cm (16 inches) thick. It is not faced with brick or similar. The images confuse me: although the attachments here are labeled “survey,” what good is a survey without measurements? Furthermore, the plans in the earlier thread (see post #2 here) include measurements and clearly show a 41cm (16 inches) thick, three-layer wall excluding plaster: a 17.5cm (7 inches) load-bearing masonry shell, probably mineral wool insulation or similar with a 12cm (5 inches) cavity, and an 11.5cm (4.5 inches) outer masonry veneer layer that is excessively thick for merely supporting plaster. This does not appear to be a professional architect’s remodeling plan. Were you the buyer and not the builder or original occupant?
