ᐅ Window opening options with controlled residential ventilation – planning ideas
Created on: 1 Nov 2020 14:22
pagoni2020
After deciding to install a controlled residential ventilation system, my mindset regarding the possibility of opening windows has perhaps changed. I would appreciate hearing about your experiences on this topic.
We plan to design the larger glass areas in the so-called open space with a 1/3 to 2/3 ratio, meaning each would have one hinged door (no tilt-and-turn function); the large window by the dining table would even be fixed glass, while the individual rooms would have at least part of the window as an opening casement.
Originally, I wanted everything to be fully openable, at least to be able to bring in larger items if needed, and especially to ventilate at 150% capacity since I am a fresh air enthusiast. However, with controlled ventilation, fresh air is already supplied throughout the house, so I would essentially just have to change my mindset that used to tell me to open all the windows wide.
This way, I could install significantly more fixed glass, for example in the loft area where I had actually planned an automatic opening for ventilation.
Somehow, I still feel that I should be able to open everything, but that seems to be just a feeling rather than a real necessity.
For example, in the bathroom or even more so in the kitchen, I could install a very wide strip of uninterrupted glass—but then I wouldn’t be able to open the window.
What am I overlooking in my considerations, or what suggestions do you have on this topic?
11ant4 Nov 2020 22:19
Anna_BW schrieb:
Sliding components and insect screens?
Placed on the outside, in front of the opening part, either sliding themselves or as a hinged sash (usually only in the width of the passage).
Climbee5 Nov 2020 08:54
For mosquito protection, we also have sliding panels, as 11ant mentioned, sized to match the operable part of the window. There is a track running the entire length of the window, allowing us to slide the insect screen back and forth. In winter, we lift it out of the tracks and store it away. Since the panels are really lightweight, it’s no big deal. We ordered them at the same time as the windows, and they come in exactly the same color as our windows (not anthracite or white, but a shade called ETA – some kind of brown that matched the weathering wood better than anthracite).
For the regular windows, we have fixed panels that are hooked in and also have frames in the same color as our windows. As I said, we ordered these directly with the windows, so the fit is very good (and I would recommend this approach to anyone).
The screens are hardly noticeable, except when it rains – then the droplets behave differently on the windows. Honestly, I would prefer not to have insect screens at all… but we can’t do without them here. Although in our household, it’s actually my husband who keeps the bugs busy 😎
Right now, we still have so many mosquitoes that the screens are still up. But every evening I see swarms of those nasty creatures clinging to our windows, practically begging to be let inside because of the cold. And as a bit of a tough one myself, I take a certain dark pleasure in knowing that they will probably meet their end during the first frosty nights! *harharhar*
Würfel*
5 Nov 2020 11:12
hampshire schrieb:
We have many very different social and quiet areas, warm and cool, indoors and outdoors, and nearly every combination in every season. We find that works better for us.
Exactly, we do too. That’s why we enjoy warm summer rain outside on the covered terrace. In summer, our terraces and other partly covered garden spots are basically our living and dining rooms; I would never think of sitting inside with the window open. Mosquitoes aren’t a big problem for us either. In fact, we have a sliding patio door by the dining table, but we rarely use it because next to it is the living room door, which leads directly to the main terrace.
@Pagoni: As you can see, people here have very different needs and conditions (mosquitoes, terrace size, covered terraces…). You’ve now heard many advantages and disadvantages and ultimately have to decide for yourself. The doors on the right and left are probably more accessible since there’s no table blocking them and will likely be your main routes to the outside.
@hampshire: That huge window front for complete opening at your place is really brilliant, I like it a lot, and it definitely should never be fixed glass. But for Pagoni, we are talking about ONE of the three 3m (10 feet) windows.
haydee
5 Nov 2020 13:59
At our home, the lift-and-slide door by the dining table is the most frequently used door. Usage varies a lot, though.
If budget is not the main concern, I would recommend making every window operable. Even if you don’t use it often, it’s easier to clean, and if you want to use it but it doesn’t open, it can be frustrating.
pagoni2020
5 Nov 2020 14:36
Würfel* schrieb:
You’ve now heard many pros and cons and ultimately have to decide for yourself.
Fortunately, only 49% 🤨
haydee schrieb:
For us, the lift-and-slide door by the dining table is the most frequently used door.
From my experience, I tend to use the hinged door more; maybe it was because the sliding door used to be very large.
Würfel* schrieb:
Mosquitoes are not much of a problem for us.
That could actually be a problem for us, and usually only for me. It’s really beautiful here at the moment but terrible when it comes to mosquitoes.
The decision has to be made this weekend, and some thoughts from here have already been incorporated... still under construction.
haydee schrieb:
If it’s not about saving every last cent,
I might save a little here and there. I would never think of economizing on the best side of my house. More likely on the garage, automation, fences, and other small extras...
haydee
5 Nov 2020 16:43
Whether it’s a garage or a carport doesn’t really matter, but a fixed window element positioned in the wrong place always bothers me. I believe you can only somewhat predict in advance how and what you will use. This only becomes clear in reality.
