ᐅ Controlled residential ventilation: Placement of supply and exhaust air in my designs
Created on: 12 Oct 2020 00:03
Shiny86
could you please review our plans regarding the supply and exhaust air locations?
I’m quite overwhelmed. Visually, the vents don’t look good at all, but they have to go somewhere. What is the most elegant way to solve this?
Do you think this layout is good?
At first glance, the supply air position in the living room (ground floor open plan, left side) stands out. The sofa will be placed directly underneath it...
Also, on the upper floor, there are three supply air vents on the floor. I find that rather unattractive and I’m concerned it might be inconvenient for cleaning.
Is it possible to simply change these floor vents on the upper floor to ceiling vents, or would that involve significant additional costs?
I would appreciate your feedback.
Thank you in advance!
I see the HAR DD, but no BD directly above it in the bathroom (?)I think they don’t have to be exactly aligned. In children’s rooms, they’re also not located directly above the DDs in the living area.
halmi schrieb:
Isn’t the exhaust air missing on the upper floor, or did I miss something?There is a wall vent shown, right next to the toilet in each case.
At least for the Monroe effect, they are exactly right.
Mycraft schrieb:
It depends on the type of screed you use. If it's too close to the window, it might crack. But basically, you can do it however you want. How close are yours to the window?
I measured ours: they start 25cm (10 inches) away from the window. I saw a picture online where there was only 7cm (3 inches) between the window and the floor grid. That’s why I’m asking. I just don’t want ours to be unnecessarily conspicuous. I’m not sure what’s common practice...
