ᐅ Privacy screen for the bathroom window
Created on: 10 Oct 2016 22:52
Maria16
I’m currently thinking about options for privacy protection on our bathroom window.
Clear glass would be my preference because it suits the uniform façade design, but my partner finds curtains impractical in the bathroom. He leans towards frosted glass.
Now I’ve come across frosted window film, which can be applied afterward. The advantage is that I could install it only once I’m in the finished house and realize that privacy is really an issue. It could also be applied only to the lower part of the pane.
My concern is whether the film might eventually peel off due to moisture from steam (and I like long, hot showers...).
Has anyone had experience with this? Or are there completely different ideas for privacy solutions?
Thanks in advance!
knalltüte
17 Aug 2020 16:55
Hi,
There are films available in all patterns, colors, and finishes. I have several in the bathroom and workshop (office). None of them have ever peeled off, not even a little.
Installation is easy if you use a wet method. Just fill a spray bottle with water and add a single drop of dish soap. Spray the surface thoroughly (a liquid film must be present). Place the film and slide it into position until it fits. Of course, order the film to size. This usually looks better at the edges than cutting it yourself. However, it can also be done with a very sharp utility knife.
In the bathroom (apartment) on the first floor, I covered nearly half the window with a "stained glass pattern," which gives a nice light effect.
Pinkiponk
17 Aug 2020 18:27
Maria16 schrieb:
If the bathroom is on the ground floor, maybe consider privacy screening with plants?
F
Flo´s Tipps
1 Sep 2020 12:59
Superzapp, where did you get your printed films from? That sounds very interesting!
11ant1 Sep 2020 14:29
superzapp schrieb:
In the bathroom (apartment) on the first floor, I covered almost half of the window with a "stained glass pattern," which creates a nice light effect.
Zeigma, please.
knalltüte
1 Sep 2020 14:32
Hello, I ordered my first adhesive films with the design "d-c-fix Glass, Bamboo White, 67.5cm (27 inches) x 1500cm (590 inches), self-adhesive" from Amazon. It was for the bathroom in the office. The other one (for the bathroom in the apartment) was available on eBay with the design "Glass Decor Window Film, D-C-Fix, Tulia, Privacy Film, Stained Glass". The seller was called "Schmolke Folientechnik".
bauenmk20202 Sep 2020 09:50
Our site manager says that a film on our windows ("float glass") would not be a good idea. Can anyone confirm this?
(Our general contractor invokes the decisive term "warranty").
