ᐅ Room divider – single-sided or double-sided?
Created on: 1 Jul 2020 10:56
tumaa
I’m currently considering how the room divider could be designed—whether it should be accessible from both sides or just one. I’m thinking of a height of about 1.40 m (4 ft 7 in).
On one side, the TV would be mounted, and on the other side, there would be a bench.
My thoughts:
I’m not sure why, but I feel that with the double-sided accessible option, when I’m watching TV, I might notice more movement in the background, which could be distracting, although it would feel more open.
With the single-sided option, I might have more possibilities for design.
Does anyone have experience with this or any opinions?
Thanks and regards!
PS: I also find the example photo interesting.
Unfinished interior with hanging cables from the ceiling, white walls, and large window front.
Shell construction room with hanging cables from the ceiling, construction boards on the left, and blue tape on the floor.
Shell construction: empty interior with exposed cables, large windows, and construction work.
Construction interior with hanging cables; red and yellow marking lines on the floor.
Bright open living space with partition wall, modern furnishings, L-shaped sofas, and city view.
pagoni2020
12 Jul 2020 09:43
The size of the TV obviously plays a crucial role, so I would start with the 65-inch size, as well as the height of the furniture it stands on or the dimensions of the wall mounting.
From there, it largely comes down to personal preference. I would recommend checking it out in a store or furniture showroom, or trying to visualize it at home.
A 17.5cm (7-inch) deep wall unit seems quite bulky to me. It could be slimmer or have a small edge as a frame, or even a ceiling brace, depending on your taste.
tumaa
12 Jul 2020 09:49
The sofa we like should have a seat height of about 45cm (18 inches). I will ask again to confirm.
The mason recommended 17.5cm (7 inches) for stability, for example, for TV mounting, etc.
Alessandro
13 Jul 2020 07:47
So a 1.50m (5 feet) room divider seems far too low to me, regardless of the TV.
tumaa
13 Jul 2020 08:21
Alessandro schrieb:
So, I think a 1.50 m (5 feet) room divider is way too low, regardless of the TV.
I don’t want to interfere too much with the open-plan design... What height would you recommend?
Alessandro
13 Jul 2020 08:33
With a clear ceiling height of 2.70m (8 ft 10 in), I would go for a height between 1.80 and 2.00m (5 ft 11 in and 6 ft 7 in). It still feels open.
The best thing is to make a template and try it out.
An open shelf like the one @Steffi33 has is also very nice and especially practical, because it provides storage space while allowing for a lot of decoration and lighting options.
tumaa
13 Jul 2020 08:45
Alessandro schrieb:
With a clear ceiling height of 2.70 meters (8 ft 10 in), I would go for 1.80 to 2.00 meters (5 ft 11 in to 6 ft 7 in). It still feels open that way.
The best way is to make a template and try it out for yourself.
An open shelf like the one @Steffi33 has is also very nice and especially practical, since it provides storage space and allows for plenty of decoration and lighting options.
Good idea, thanks also to @Steffi33!!
I think I wouldn’t extend it all the way to the ceiling and would stick to 1.8 meters (5 ft 11 in).
Or did you mean a shelf? (from 1.8 to 2.0 meters (5 ft 11 in to 6 ft 7 in))
