ᐅ Pulling cables through a conduit (or duct).
Created on: 1 Jun 2020 07:47
gmt94
Good morning everyone,
I have the following issue. I installed a conduit with an internal diameter of 100mm (4 inches) between the house and the garage.
Inside this conduit, there is already a cable 5*16, a double network cable, and a coaxial cable. The electrician who pulled these cables through back then also pulled a draw wire.
Now, over the weekend, we wanted to pull an additional cable (doorbell) through, but the draw wire must be stuck somewhere, so we cannot pull through from either side.
How can I get my cables through there now? There should still be enough space.
Thanks for your help. Attached is a picture
Multiple cables (red and gray) leading into an open black conduit on the ground at the construction site.
gmt94
1 Jun 2020 13:30
rick2018 schrieb:
How long is the conduit? Do you have a fish tape or pulling tool so you don’t have to use the wires?
The cables are probably stacked on top of each other, which could be blocking the pull.
Once you reach 10 meters (33 feet), it gets quite difficult. As @Fummelbrett! already mentioned, it’s important to use plenty of lubricant.
I just measured, it should be close to 10 meters (33 feet).
I only have those nylon pulling guides from the hardware store, but they’re not very effective. I was able to push another empty conduit with an 18mm (0.7 inch) inner diameter up to that point. I plan to insert an inspection camera there to see why it won’t go any further. After that, I’ll figure out the best plan moving forward.
gmt94
3 Jun 2020 13:55
The endoscope arrived, and I tried it right away. It doesn’t look good around my empty conduit.
At some point during construction, it must have been damaged.
Small gap between rock with two light pebbles; orange object at the edge.
There are definitely stones inside, and it’s no longer perfectly round.
There is still space available, but the question is how I can get through there.
seat883 Jun 2020 14:36
What type of conduit did you use? Normally, it’s quite difficult to damage...
danixf
3 Jun 2020 21:28
What a pity about the conduit.
Get some lubricant and also slightly move the other cables. Most likely, use the 5x16 one. The insulation there is much more durable than network or coax cable. It only has to slide through the corner once. I don't really see an issue with a doorbell wire. But that would be the limit.
Your plan to use the existing network cable and skip the doorbell wire isn’t going to work?
gmt94
3 Jun 2020 21:52
So, hours later. Nothing gave me any peace of mind, so I lifted the paving and once again cut through compacted mineral aggregate. As is often the case in life, I got unbelievably lucky—the pipe was probably damaged during the installation of the thick point foundations for my mezzanine roof.
So now there is a huge mound of concrete over my broken pipe.
Open excavation showing orange and white cables in damaged conduit, surrounded by dust.
For the time being, we’ve connected the doorbell to a network cable. But I want to fix it properly. We are supposed to get fiber optic installed here. I already have a duct from the house to the street that runs over the garage. My plan was for them to put their cable inside that without destroying my entire property again.
You have 1100m² (11840 sq ft) of land, and concrete and duct come together to the millimeter.
Excavation hole with orange and white conduit in the ground.
Vicky Pedia3 Jun 2020 22:05
The empty conduit now appears to be the weak point. Isn’t it possible to lay the new cable next to it as an underground cable or in a new conduit? The camera and related equipment cost a significant amount.
