ᐅ 6-year-old house with cracks in the plaster and broken bathroom tiles – is this considered a construction defect?
Created on: 12 May 2020 10:28
aldi1985
aldi1985
12 May 2020 10:28
It took a long time, but we have finally found our dream property.
However, there are a few things that make us uncertain.
The house is 6 years old, so unfortunately the warranty has already expired.
It is a solid masonry house built with Poroton bricks.
On the upper floor, there are noticeably many cracks (on the ground floor, we did not see any cracks). Some of them run straight through the wall.
I have attached two pictures. The crack is on a 17.5cm (7 inch) thick masonry wall. On the back side of this wall is the bathroom. Apparently, the crack caused 3 bathroom tiles to crack.
Are these cracks cause for concern?
The seller said that such cracks are normal in new buildings. He himself was told this when he tried to report it as a defect to the construction company about 2-3 years ago.
Thank you very much
Grey tiled wall with two switches, thermostat on the left, mirror with mosaic frame; spray can on the right.
White ceiling with diagonal crack line, near a square ceiling light.
HilfeHilfe
12 May 2020 10:57
Yes, settlement cracks—masonry does shift over time. Although I find that quite severe when it comes to tiles.
Have you considered getting an expert assessment?
T_im_Norden
12 May 2020 11:26
Without assessment by an expert engineer/structural engineer, I would consider this too risky.
nordanney
12 May 2020 11:32
aldi1985 schrieb:
Are these cracks a cause for concern?
Usually not, as they are typical settlement cracks.
Yes.
I have a rented apartment where, even 55 years after completion, cracks appeared on a wall after some work was done outside near the sewer.
Annoying, but more of a "cosmetic defect."
Lumpi_LE
12 May 2020 11:33
These cracks are quite unusual... however, as a defect in relation to the builder, they are difficult to claim. As a buyer against the seller, though, it's not a problem.
aldi1985
12 May 2020 11:34
Unfortunately not; what would be the worst-case scenario? Would the wall need to be rebuilt? Or could it even indicate problems with the foundation slab? Surprisingly, as mentioned, there are no cracks on the ground floor.
