Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
@kbt09, in certain areas one gender group is clearly more represented than the other....
Why are you reacting like this and calling me chauvinistic...?
It’s simply because you are annoyed due to other threads and my statements…. I call that freedom of expression.
Either you have to accept it or you are out of luck… as long as I don’t personally attack anyone, everything is fine….
Still: why are all cables yellow? – Color helps with organization.That makes more sense in the server cabinet. You handle the installation cables once and connect them to the patch panel. Afterwards, you connect the switch ports to the patch panel ports using short patch cables. That’s where you can use colors (e.g., all access points get white patch cables, all cameras get black ones, and so on).
In fact, the color options for patch cables are quite limited, so one cable manufacturer might not be enough for Rick if he wants to work with colors.
In my cabinet, for example, I have
Draka green
1attack green
because otherwise, the color selection wouldn’t have been sufficient.
@superzapp
The patch cables are color-coded by (V)Lans, functions, and locations.
I'm not sure about the manufacturer at the moment. I need to check tomorrow.
It's CAT7 with more than 1000 MHz. We initially wanted to go with CAT8, but it doesn't really provide any advantage for us and was more expensive right now...
knalltüte2 May 2020 15:27dhd82 schrieb:
In fact, the choice of colors for patch cables is not very wide either; for Rick, one cable manufacturer might not be enough if he wants to work with colors.
Draka green
1attack green
because otherwise the selection of colors would not have been sufficient.Well, actually, it is. There are plenty of colors available, especially from brand-name manufacturers.
Unless you really need more than 6-8 colors, but that is rarely the case.
Telephony, LAN, possibly DMZ for a private area, cameras (PoE?), router (WAN), NAS, server...
Then feel free to mix manufacturers, because (as [B]dhd82 mentioned) green is not always the same green.
