ᐅ Looking for a construction company in the Greater Stuttgart area!
Created on: 18 Sep 2018 21:18
budbrd
we have purchased a plot of land near Stuttgart and submitted a building permit application. Unfortunately, the cost estimates keep increasing.
The project is a single-family house with a living area of 250 m² (2690 sq ft), including a double garage and basement, KfW40+ standard.
Can anyone recommend a construction company in the greater Stuttgart area?
Thanks in advance!
Thanks in advance!
Markuss8528 Apr 2020 07:30erazorlll schrieb:
we have made our decision!Great, congratulations on your decision! And of course, many thanks especially for the detailed and thorough description; this will surely be very helpful for future home builders in the region.
I wish such a detailed thread had existed two years ago.
Wishing you continued success and all the best with the construction!
Markuss85 schrieb:
this will certainly be very helpful for future builders from the regionIn this specific case, of course, especially for those from the region – but I also find the way of storytelling exemplary, so that other builders sharing their own experiences can follow this approach to present their insights in the most reader-friendly way.https://www.instagram.com/11antgmxde/
E
erazorlll10 May 2020 15:17Baufie schrieb:
Then I hope you'll be just as satisfied with my advice in the end as my colleague was.
Will you also be sharing plans of your project? Yes, that’s the plan. I’ll let you know.
First, we want to have a solid design that works well for us and then present it here for discussion.
E
erazorlll3 Jun 2020 16:59A brief update from my side:
We had a planning meeting and then received the first draft. It already looked quite good and was close to our ideas. Afterwards, we requested a few changes and received a new version of the draft. Unfortunately, we then realized that our preferred kitchen layout did not fit into the space or floor plan. In a second meeting, we discussed the options and tried out a few alternatives. The change unfortunately meant that the staircase had to be relocated, which resulted in modifications to the rooms in the basement and upper floor.
We are now waiting for the updated draft, and if it meets our expectations, I will share it here.
Evelyn! schrieb:
Unfortunately, the link doesn’t work?You need to do a quick fix: change Threads to threads, and then the link won’t break. This is a general bug here.Your email has arrived. What do the 34cm (13 inches) refer to: 24cm (9.5 inches) wall plus 10cm (4 inches) insulation (I thought you wanted it without)?
