ᐅ Design of Rainwater Infiltration (Swale)
Created on: 26 Apr 2020 15:11
V
VolkerRacho
V
VolkerRacho
26 Apr 2020 15:11
our building regulations require surface water infiltration. According to calculations from our paver, we will likely need:
1) 80 m² (860 sq ft) with a detention depth of 30 cm (12 inches)
or
2) 25 m² (270 sq ft) with a detention depth of 100 cm (39 inches)
I understand this to mean that I can either have a "wide, shallow" infiltration basin or a "narrow, deep" basin. Is that correct?
If I choose the "deep" option (to avoid losing too much lawn area), could I practically create a planting bed there (with plants that can tolerate occasional wet feet) and use it as an infiltration basin? Does anyone have experience with this?
I also read that the basin must be at least 3 m (10 ft) away from the property boundary. Does this apply on all sides (including where I don’t have neighbors, such as the street side)?
Regards,
VK
Vicky Pedia26 Apr 2020 15:26
Build a soakaway, since you won’t see anything except a manhole cover. The crucial factor is the volume that needs to be filled at the same time.
V
VolkerRacho
26 Apr 2020 15:34
In my opinion, I am not allowed to do that; it is not surface infiltration. The building regulations explicitly require a basin...
Vicky Pedia26 Apr 2020 17:43
VolkerRacho schrieb:
In my opinion, that’s not allowed; this is not surface infiltration. The building regulations explicitly require a basin...
Haha! Then the basin will be made correspondingly smaller and planted.
Lumpi_LE
26 Apr 2020 18:09
We are also required to have soakaways. One person thought he didn’t have to follow that rule and built a French drain instead. He had to remove it and pay a fine.
We also have about 100m2 (1,076 sq ft), 30 cm (12 inches) deep. We simply integrated it into the lawn area and have regular grass growing on top. It doesn’t cause any issues, and I don’t think water has ever pooled there.
Vicky Pedia26 Apr 2020 19:52
That amounts to 30m³ (35 cubic yards). Where is so much water supposed to come from during rain?
