ᐅ Insulation in the 1970s Compared to Today, Modern Insulation, Heating Costs
Created on: 5 Nov 2012 10:29
meisterlampe
meisterlampe
5 Nov 2012 10:29
I would be interested in an assessment of how much higher heating costs (in percentage) you can expect in a house built around 1970 with solid construction according to the standards of that time (including windows), compared to modern insulation as commonly used today.
Are there significant differences? This concerns exterior walls and the roof.
Where are the biggest heat losses likely to occur? Exterior walls, windows, or the roof?
Which renovations would be particularly necessary, and which ones less relevant?
Thank you
Meecrob
5 Nov 2012 15:17
No one can really give you a definitive answer to that. Usually, the actual surface areas and their values are calculated. Then climate data and individual needs are also taken into account. It’s too complex for a simple statement.
What type of wall construction do you have? Insulating the roof is usually fairly straightforward and already provides significant benefits.
€uro
5 Nov 2012 19:14
Meecrob schrieb:
..... Then there are climate data and individual needs to consider. Too complex for a simple statement.
Absolutely correct!
Additionally, extra insulation must always be evaluated in connection with the building services engineering. With a water-source or brine heat pump, one can often avoid excessive insulation measures; with gas condensing boilers, air-source heat pumps, or wood burning, somewhat more insulation is usually advisable! However, this should be targeted and purposeful. Usually, an adjustment of the heating system is necessary; otherwise, the "optimistically calculated" energy-saving measure will simply dissipate.
Best regards.
meisterlampe
6 Nov 2012 11:23
Ah, what do W- or brine heat pump and gas condensing boiler, air heat pump mean? To what extent does the heating system need to be adjusted according to the insulation?
Musketier6 Nov 2012 11:40
These are IDE heating system types:
Ground source heat pump
Air source heat pump
Gas condensing boiler
Musketier6 Nov 2012 11:46
Insulation reduces the amount of heat required. This may result in the existing heating system being oversized and operating inefficiently.
The energy savings achieved through insulation are therefore at least partly lost.
