ᐅ Mandatory Floor Insulation in the Attic
Created on: 12 Apr 2020 22:04
Grokobud
Grokobud
12 Apr 2020 22:04
Hello, I own a house built according to the 2016 Energy Saving Ordinance.
The space below the roof is used as a storage room and is accessible via a retractable ladder.
The roof is insulated with insulation placed between the rafters.
I have now read that it is mandatory to also insulate the ceiling. The ceiling joists in my case are not insulated, and I installed the walkable surface with panels myself.
Can someone confirm if this is true and provide a reference to the relevant regulation text?
Thank you very much
Vicky Pedia12 Apr 2020 22:06
As I understand it: the ceiling on the upper floor is not insulated? Only rafters with catwalks?
12 Apr 2020 22:08
Grokobud schrieb:
The roof is insulated with insulation installed between the rafters.
If the roof is insulated, then the floor, meaning your upper floor ceiling, does not need to be insulated.
Grokobud
12 Apr 2020 22:16
The ceiling in the attic is not insulated; I have placed boards on the rafters. The attic has a drywall ceiling, with the storage room located above it.
12 Apr 2020 22:17
If the roof is insulated, the floor, meaning your upper floor ceiling, does not need to be insulated.
Grokobud
12 Apr 2020 22:23
ok thanks
