we are in the final planning stages of our future two-story home.
The upper floor is smaller than the ground floor and therefore has a 35 m² (about 377 sq ft) flat roof. Below it is the living space of the ground floor.
Now we are considering converting this area into a balcony.
The construction company wants to charge €880 per m² (about $880 per 10.8 sq ft), which means an additional €30,800.
I am still quite inexperienced, but this seems somewhat overpriced.
What do you think?
Many thanks for your opinions!
What do you think?
hampshire schrieb:
The structural requirements for a balcony terrace are quite demanding and mean that you need a different construction. Add a surface covering and a railing, and suddenly the price doesn’t seem that high anymore. Thank you very much for the response. Am I correct in understanding that the balcony terrace is not built on the flat roof itself but completely as a separate structure? If so, the price definitely doesn’t seem too high.
Therefore, since the flat roof has surely already contributed significantly to the total house cost, that amount should be subtracted. Or am I overcomplicating things?
AxelH. schrieb:
Great house, very well done!eugensit schrieb:
Or am I overcomplicating this?Although the question wasn’t directed at me, this was our situation:
Reinforced concrete ceiling for the entire ground floor – included in the price.
Flat roof with tapered insulation and appropriate waterproofing – included in the price.
Parapet capping in anodized aluminum – included in the price.
So, for the calculated house price, only the additional rows of masonry had to be added. This had about the same negligible impact on the overall house price as plastering the extra brick rows.
Additional costs arose only from the protective mat placed between the waterproofing and the roof terrace, and from the terrace construction itself using WPC decking.
Axel
hampshire3 Apr 2020 20:54I recalled that the load-bearing capacity of a flat roof must be designed differently for pedestrian use compared to when the roof is not intended to be accessed. This would require a different construction if the planned roof does not already meet this requirement.
