we are in the final planning stages of our future two-story home.
The upper floor is smaller than the ground floor and therefore has a 35 m² (about 377 sq ft) flat roof. Below it is the living space of the ground floor.
Now we are considering converting this area into a balcony.
The construction company wants to charge €880 per m² (about $880 per 10.8 sq ft), which means an additional €30,800.
I am still quite inexperienced, but this seems somewhat overpriced.
What do you think?
Many thanks for your opinions!
What do you think?
eugensit schrieb:
We are in the final planning stages of our future two-story home. I don’t see anything.
eugensit schrieb:
The upper floor (first floor) is smaller than the ground floor and therefore has 35 m² (375.9 sq ft) of flat roof. Beneath it is living space on the ground floor. We are now considering converting this area into a balcony. At first, that sounded like a possible issue with full storey classification, but according to your profile, you are in Brandenburg, where this does not matter. So why the discrepancy in the floor sizes? — see above
I don’t see anything.I will gladly share the pictures once this last question is resolved and the planning is finalized.11ant schrieb:
At first, I thought this might lead to a full storey issue. But according to your profile, you are from Brandenburg, where that doesn’t matter. So why is there a discrepancy in the storey heights? – see above Well, that was purely a matter of personal preference.H
The construction company wants to charge €880 per m2 (approximately $82 per ft2), so around €30,800 (about $34,000) total.
I’m still quite inexperienced, but this seems a bit overpriced.
What do you think? The structural requirements for a balcony terrace are quite demanding and mean that you need a different construction. Then add a surface covering and a railing, and the price doesn’t seem so high anymore.
eugensit schrieb:
Now we are considering converting this area into a balcony. Hello Eugensit,
we did the same. The planned parapet wall was simply built up a bit higher, which didn’t add much to the cost. On top of the flat roof covering, a protective construction mat was installed. That cost an additional 500 euros. I then installed the terrace flooring made of WPC myself.
AxelH
eugensit schrieb:
I will gladly post the pictures as soon as this last question is resolved and the planning is finalized.That’s a classic catch-22 situation.https://www.instagram.com/11antgmxde/
