ᐅ Roof terrace with slab paving on pedestals – maintenance and cleaning
Created on: 1 Apr 2020 11:38
Corini1985C
Corini19851 Apr 2020 11:38Hello,
we have a roof terrace with slabs on pedestals. How often should the slabs be removed to clean the substrate, or at what intervals do you usually do this? Annually?
Thanks
Thanks
nordanney1 Apr 2020 11:46Corini1985 schrieb:
How often should the panels be removed and the substrate cleaned, or how frequently do you do this? Why do you want to clean the area beneath the panels if it’s not visible at all? I don’t have a construction like that myself, but I can’t think of a reason to access that space.
Corini19851 Apr 2020 13:02It’s not a matter of wanting to, but my understanding was that this should be done because dirt or other debris could accumulate there...
nordanney1 Apr 2020 13:35Corini1985 schrieb:
because dirt or other debris could definitely accumulate there... So? Does the dirt you can’t see bother you?
For example: do you take down your 3m (10 feet) long wardrobe in the bedroom every year because dirt could build up behind it? It’s the same with the panels. If weeds grow a meter (3 feet) high out of the joints, you might want to address the root cause (or simply use weed killer like RoundUp). But cleaning away "dirt" is not necessary.
