Do you use the same tape for the joint that is also stuck to the wall? A screed installer on MyHammer told me that this is not done. Apparently, there are people on MyHammer who know what they’re talking about...
Quote from the email:
Please do not use edge strips as expansion joints (in areas like doors, etc.). Otherwise, the screed cannot be guaranteed to be level from room to room, and as you can see, the joints cannot be made straight.
What should I use instead?
jamguy schrieb:
Why does there have to be an expansion joint there? Normally, you wouldn’t do it that way, but you can.Why… why wouldn’t there need to be one? How should it be, or how must it be? When is it necessary, and when is it not?
Sharky schrieb:
Why... Why doesn’t one have to go in there? How is it supposed to be, or does it have to be? When is it required, and when is it not required...Comedian! 🙂
jamguy schrieb:
Comedian! 🙂But I still haven’t received an answer on whether nothing should be installed there or if something else needs to be added...
