ᐅ Open kitchen: exhaust air or recirculation with controlled residential ventilation & KfW 55 standards
Created on: 13 Jan 2020 17:32
micric3
Hello forum community,
When it comes to kitchen exhaust/recirculation systems, opinions vary widely.
Keywords like thermal bridge, replacement air (supply air), wall duct, negative pressure, controlled residential ventilation bypass do not make the topic any less complex.
I would like to hear first-hand experiences from homeowners here.
- Who has controlled residential ventilation along with kitchen exhaust?
- Who has kitchen exhaust with separate supply air (possibly also through a wall duct)?
- Wall ducts apparently withstand a blower door test, but how do they perform regarding possible thermal bridges?
- Who has opted for recirculation instead of exhaust, and why?
- How is the odor situation, especially in an open kitchen?
Good luck
Good luck
Hello, I read the thread with interest because we are currently in the middle of planning our kitchen.
The kitchen is just under 18m2 (194 sq ft), with a finished ceiling height of 2.85m (9 ft 4 in), KfW55 standard but no central ventilation.
We also want a recirculating hood.
The hood will be installed over an island with a 90cm (35 in) gas cooktop.
Right now, I’m trying to decide whether a chimney hood, a suspended hood, or even a ceiling-mounted hood would be best.
What would work with the ceiling height, be effective, and not look too ugly (a large drywall installation hanging from the ceiling is not ideal either)...
I would like to hear about 2 or 3 models that could do a good job.
When I browse Novy’s website, I get confused because I don’t see anything with 1000 cubic meters per hour, only max 600 to 700 cubic meters per hour, which is probably too low.
We don’t need a designer model for $5000, I just want something that works well.
Thanks,
tauber19
Thanks,
tauber19
tauber19 schrieb:
Hello, I have been reading this thread with interest as we are currently planning our kitchen.
The kitchen is just under 18m² (194 ft²), finished ceiling height is 2.85m (9 ft 4 in), KfW55 standard but no central ventilation.
We also want a recirculation hood.
The hood will be installed over an island with a 90cm (35 inch) gas cooktop.
Right now, I’m trying to decide whether to go with a chimney hood, a suspended hood, or a ceiling-mounted hood.
What works best with the ceiling height / is effective but also doesn’t look too unattractive (a huge drywall construction hanging from the ceiling is not ideal either)...
When I look at Novy on their website, I’m confused, I don’t see anything with 1000 cubic meters per hour, just max 600 to 700 cubic meters per hour, which is probably too low.
We don’t need a designer piece for $5000, I just want something that works well.
Thanks
tauber19 This is how we did it. The Siemens unit is decent.
https://www.hausbau-forum.de/threads/Küchenbilder-Thread-zeigt-her-eure-Küchen.28518/post-375207
It produces 850 cubic meters per hour on boost mode and the calendar on the wall flutters. We have a 120cm (47 inch) hood over a 75cm + 30cm (30 inch + 12 inch) cooktop.
The boost produces 850m³ (30,020 cubic feet), and the calendar on the wall is flapping. We have a 120cm (47 inch) hood over a 75 + 30cm (30 + 12 inch) cooktop.
[/QUOTE]
Thank you very much! One more question: what is your ceiling height? Is it raised as well? We are planning for 285cm (112 inches).
[/QUOTE]
tauber19 schrieb:
The hood moves 850 m³/h (about 500 CFM) at boost, and the calendar on the wall flutters. We have a 120 cm (47 inch) hood over a 75 + 30 cm (30 + 12 inch) cooktop. Thanks a lot!
One more question: what is your ceiling height? Also raised? We are planning 285 cm (112 inch).
[/QUOTE]
Around 250 cm (98 inch).
