We are planning to build or buy a rainwater cistern. Has anyone here had experience with this? The cistern is primarily intended for garden irrigation.
According to the development plan, rainwater infiltration on the property is not allowed.
Concrete?
Plastic?
What else should we consider?
Toilet connection?
Where to position it?
I would like to take this into account directly during the excavation for the foundation slab and have the hole dug at the same time.
Looking forward to your ideas and tips.
Concrete?
Plastic?
Toilet connection?
Piotr19811 Feb 2020 20:53kaho674 schrieb:
Yes, the 23,000 liters (6,100 gallons) should be enough for an initial firefighting water supply. There are minimum required amounts. One year later, a public 100,000 liters (26,400 gallons) cistern was built right across the street. Very frustrating, especially since we had offered to share part of the costs for a public project. But I’ll just say "the authorities".Do you have a concrete or plastic cistern?
Piotr1981 schrieb:
Do you have a concrete or plastic cistern?Concrete.P
Piotr19811 Feb 2020 21:04kaho674 schrieb:
We had to install two cisterns for firefighting water, which we are now allowed to repurpose. Back then, the two units cost about 5,000 euros each including installation for 23,000 liters (6,075 gallons). Connecting them to the household drainage was fairly straightforward – much more complex is the planning of the irrigation system. May I send you something via private message?
Piotr19811 Feb 2020 21:08kaho674 schrieb:
Sure, although I’m afraid I don’t have much more to add on that part.I just realized I can’t write right now oops:
Even with a 500m2 (5400 sq ft) plot, I would lean towards building a 10,000-liter (2,640-gallon) tank. This way, you can store some water during rainy periods and in winter. Depending on how the garden is designed, even a small garden can use several square meters per watering session.
I don’t mind whether the tank is made of concrete or plastic—it depends on what fits better in terms of size, shape, and price.
I would install a fine mesh inlet filter with backwash function right from the start. It can also be used as a source for fresh water supply.
Choose a pump with sufficient capacity and pressure, especially if it’s for irrigation purposes.
Don’t try to use the cistern water for toilets or similar household uses. It simply doesn’t make sense (double plumbing, etc.). Also, the cistern will be too small if you want to water the garden. After two to three dry weeks at the latest, it will run dry.
