ᐅ Light connection installed in the wrong location for the guest bathroom
Created on: 25 Jan 2020 20:36
Janbaut
I am currently trying to solve a problem in our guest bathroom. Contrary to the original plan, the light connection for the toilet was installed on the wall instead of the ceiling, directly above the washbasin. A mirror is supposed to be installed there.
The bathroom is very small, only 2 sqm (22 sq ft).
Do you have any solutions for this issue? Would lighting from a mirror with built-in illumination be sufficient? Do you have any experience with that?
I have attached a picture of the bathroom. Unfortunately, the light connection is not visible. You can roughly see where the light comes from. At the moment, there is a bare bulb holder installed.
Small bathroom with wall-mounted toilet, wall-hung washbasin, chrome faucet, and gray patterned floor tiles.
Müllerin
25 Jan 2020 21:53
Logically, that is sufficient... we unnecessarily have an additional ceiling outlet – and for ME, it is always way too bright in that small room.
hampshire
25 Jan 2020 22:07
Stylish solution for ceiling lighting without major renovations:
Replace the switch with a porcelain surface-mounted switch and run an attractive cable with porcelain fittings up to the ceiling, then along the ceiling to the lighting point, and connect a lamp. Gi Gambarelli offers this, for example the White-Italy series. You can search online; it’s an Italian site with limited German translation but good images.
It might also be possible to bring power from an adjacent room (e.g., utility room) and make the light switchable or activate it with a motion sensor.
I wouldn’t want to miss the ceiling light in the guest toilet (though the mirror is still missing here) — photo taken from the floor upwards.
Hund schaut durch quadratischen Lichtschacht in einen Innenraum
Janbaut
25 Jan 2020 22:22
Thanks! For all your many responses. I’m really bad at choosing lighting, unlike with tiles .
When selecting lighting, practical use always needs to be considered alongside aesthetics. Well, I’ll go look for a suitable mirror with lighting now!
Thanks!
Bookstar
25 Jan 2020 22:55
Score the plaster and cut into the ceiling with an angle grinder, then pull the cables. Done. Not a big deal.
25 Jan 2020 23:55
Janbaut schrieb:
When choosing lighting, besides "looking good," practical use must always be considered.
That’s why it should be placed on the wall above the washbasin! That’s what you call practical.
Crossy
26 Jan 2020 10:08
In our guest bathroom, only lighting next to the mirror is planned. Could you also share the tile manufacturer and name? You really had a good eye for that.
