ᐅ Building a Single-Family Home With or Without a Basement on a Small Plot of Land
Created on: 24 Jan 2020 08:25
Davidoff86
Good morning everyone,
In our house planning process, like many others, we are facing the question of whether to build with or without a basement.
We have a flat, 225 m2 (2,422 sq ft) plot, on which, according to the development plan, we are supposed to build a single-family house. The house consists of a ground floor, first floor, and a recessed top floor (this is required by the development plan) and has a maximum gross building footprint of 9x9 m (30x30 ft), so we expect a living area of at least 150-160 m2 (1,615-1,722 sq ft). Under these conditions, the basement question is quite complicated.
Arguments in favor of the basement:
  • A basement obviously offers a lot of space, for example, for building services, laundry, storage, etc.
  • Without a basement, we definitely need a utility room on the ground floor. Although the external dimensions of 9x9 m (30x30 ft) would allow for this, we would prefer to use that space differently (e.g., my wife is a teacher and needs a home office);
  • We will build a 10x3 m (33x10 ft) garage with an extra room, but this is limited to about 4x3 m (13x10 ft), where we have to store bicycles and garden furniture. Unfortunately, there is no more space, e.g., for a garden shed or similar;
  • We currently have one child but plan for at least a second or even a third. The space could therefore become tight;
  • Higher property value.
Arguments against:
  • Due to the high groundwater level, the basement must be built as a watertight structure ("white tank" method), which means:
  • High costs—I estimate at least €60,000–70,000 (utility basement, with few or no windows);
  • Despite the watertight construction, I am still concerned about moisture, for example, if the basement is not built correctly. A house with a damp basement is worth less than one without;
  • The idea of more children is, of course, uncertain. What if more children do not come? We would have a large house with little use for it.
And so on...
I know there are many, partly inconsistent (what if...) factors involved. Also, the topic of basements is always sensitive; some are generally in favor, others generally against.
Nonetheless, I would be very grateful for concrete and objective advice. Perhaps some of you have faced the same issue under similar conditions (small plot, strict development plan regulations, no free layout expansion of the ground floor, soil conditions, etc.) and I would be interested to hear how this was or is resolved regarding building services and storage space.
For better understanding, I am attaching the development plan.
Many thanks to everyone who would share their experience with me. Best regards
Lageplan eines Bebauungsgebiets mit grünem Parkbereich, pinken Bauzonen, gelb gestreiften Flächen und Straßen
Legende der Bauordnung: Symbole zu Nutzungsarten, Flächen, Höhen und Beispielskizzen.
11ant24 Jan 2020 12:02
If the building line is specified in the legally binding development plan, it must be followed. Deviating from it would require at least a formal, written approval, which means you would lose the usual exemption that is commonly possible in Bavaria. However, I wouldn’t recommend retreating from it either. It seems there is an urban planning concept behind this, and in my mind’s eye, the recessed top floor on the street side is also not set back.
With or without a basement, I see the top floor containing an utility room, a roof terrace, and in between, a “studio”-sized storage room that serves as a passage, that’s it. There’s no room for romanticizing in the plan; you can forget about a 9 x 9 m (29.5 x 29.5 ft) space, and you will easily fill a 9 x 10.5 m (29.5 x 34.5 ft) area to capacity. Does your wife smoke? (if so, I would suggest setting up the office in the studio).
kbt09
24 Jan 2020 12:08
Whether the garage is on the north or south side... unfortunately, the site plan isn’t very clear.
How much space is left to the north of your building plot?
And maybe you could measure the property—overall width and length.
Perhaps you could also take a screenshot of the relevant section from your PDF—zoom in on the PDF view and then capture the screenshot.
kaho67424 Jan 2020 12:08
2.5 stories should be just enough for 4 people in my opinion. If there are 2 children instead of 1, it will get tight. Then the basement should definitely be included, I think. (Having 3 children is something you have to be able to afford. Here comes the usual space and children discussion again.)
Whether to have a basement or not sounds a bit casual. What about the finances? If that’s not an issue anyway, I would always build it.
kaho67424 Jan 2020 12:09
kbt09 schrieb:
Whether the garage is on the north or south side ... unfortunately, the site plan is not very clear.
How much space is left on the north side of your building plot?
And maybe the plot can be measured ... total width/length.
I would strongly estimate about 15m x 15m = 225m² (1610 sq ft).
kbt09
24 Jan 2020 12:11
The plot itself is not square, only the building area is.
11ant24 Jan 2020 12:17
kbt09 schrieb:
Whether the garage is north or south ...
It seems that both north and south allow a building width for "auxiliary structures: garage, carport, parking space." I estimate 3 meters (10 feet) to the north, and to the south (measured) six halves, so also 3 meters (10 feet), totaling 15 meters (49 feet) in total width within a building envelope of 9 meters (30 feet) wide and 10.5 meters (34 feet) deep.
