ᐅ Building a Single-Family Home With or Without a Basement on a Small Plot of Land
Created on: 24 Jan 2020 08:25
Davidoff86
Good morning everyone,
In our house planning process, like many others, we are facing the question of whether to build with or without a basement.
We have a flat, 225 m2 (2,422 sq ft) plot, on which, according to the development plan, we are supposed to build a single-family house. The house consists of a ground floor, first floor, and a recessed top floor (this is required by the development plan) and has a maximum gross building footprint of 9x9 m (30x30 ft), so we expect a living area of at least 150-160 m2 (1,615-1,722 sq ft). Under these conditions, the basement question is quite complicated.
Arguments in favor of the basement:
Arguments against:
And so on...
I know there are many, partly inconsistent (what if...) factors involved. Also, the topic of basements is always sensitive; some are generally in favor, others generally against.
Nonetheless, I would be very grateful for concrete and objective advice. Perhaps some of you have faced the same issue under similar conditions (small plot, strict development plan regulations, no free layout expansion of the ground floor, soil conditions, etc.) and I would be interested to hear how this was or is resolved regarding building services and storage space.
For better understanding, I am attaching the development plan.
Many thanks to everyone who would share their experience with me. Best regards
- A basement obviously offers a lot of space, for example, for building services, laundry, storage, etc.
- Without a basement, we definitely need a utility room on the ground floor. Although the external dimensions of 9x9 m (30x30 ft) would allow for this, we would prefer to use that space differently (e.g., my wife is a teacher and needs a home office);
- We will build a 10x3 m (33x10 ft) garage with an extra room, but this is limited to about 4x3 m (13x10 ft), where we have to store bicycles and garden furniture. Unfortunately, there is no more space, e.g., for a garden shed or similar;
- We currently have one child but plan for at least a second or even a third. The space could therefore become tight;
- Higher property value.
Arguments against:
- Due to the high groundwater level, the basement must be built as a watertight structure ("white tank" method), which means:
- High costs—I estimate at least €60,000–70,000 (utility basement, with few or no windows);
- Despite the watertight construction, I am still concerned about moisture, for example, if the basement is not built correctly. A house with a damp basement is worth less than one without;
- The idea of more children is, of course, uncertain. What if more children do not come? We would have a large house with little use for it.
And so on...
Davidoff8624 Jan 2020 09:51Yes, on the top floor we are planning our room, a bathroom, and an additional guest room. The roof terrace will be 4m (13 feet) deep by 9m (30 feet) wide.
Davidoff86 schrieb:
Or did I miss something?Which federal state? Depending on that, you either have to- keep a setback of 2.5 or 3 meters (8.2 or 9.8 feet) from the property line with the garage
or
- build it directly on the boundary. In this case, up to 9 meters (29.5 feet) per boundary and 15 meters (49.2 feet) in total is possible. So 10 meters (32.8 feet) is not allowed—except in the theoretical case that your neighbor permits this in the land registry; in that case, they have less usable space on their also small plot.
It really depends on your habits, whether you tend to store a lot (decorations, etc.) or rather little. Are you handy and have a fair amount of tools, maybe even want a small workshop? If you store relatively little, then a basement might not be necessary. But if you have quite a bit to store and three children are likely, I would lean more toward having a basement.
There is definitely room for improvement in the layout, including the top floor. With a 4m (13 feet) roof terrace plus a bedroom, guest room, and bathroom, that becomes quite a challenge, especially since you also need to account for stairs and hallways.
@neubau2019 and @Davidoff86, I want to ease some of the concerns. It definitely sounds alarming when a basement is flooded. However, this is rarely the case, even with a high groundwater level. Generally, the basement stays dry on the inside with a waterproof concrete shell ("white tank"). That’s exactly what this method is designed for, assuming it is executed properly. It is usually a good idea to involve a construction supervisor during the critical phases. Then, even with challenging ground conditions, having a basement is not a problem.
The definition of a setback floor is usually 2/3 of the floor area of the story below. So, 6 x 9m (20 x 30 feet) would also be possible. Alternatively, a terrace of 3 x 9m (10 x 30 feet).
Two rooms and a bathroom would fit well there, but it would really depend on the exact position of the staircase.
neubau201924 Jan 2020 10:14@Vicky Pedia you are probably right, it’s not fear but rather skepticism
