ᐅ Single-family house, 3 children's bedrooms, 2 bathrooms, approximately 10.5 x 10.5 meters (approximately 34.5 x 34.5 feet)
Created on: 7 Jan 2020 11:13
Holson!
Holson!
7 Jan 2020 11:13
we are currently planning a single-family house. We have a general contractor who is also handling the architectural design. The first proposal was quite standard and didn’t fully satisfy us, so we developed the plans further ourselves. Attached is the current version, and we would appreciate feedback especially on the location/type of the staircase and the living/dining area on the ground floor. All other information is below. Thank you very much!
Development plan/restrictions
Plot size: 511 m2 (5500 sq ft approx.)
Slope: minimal: 1 m (3.3 ft) elevation drop from west to east (over 16 m (52.5 ft))
Site coverage ratio: 0.35
Floor area ratio: 2 full floors
Building zone, building line and boundary: 2.5 m (8.2 ft) side clearance, 3 m (9.8 ft) to street
Edge development: Garage allowed
Number of parking spaces: 1.5
Roof shape: Gable roof, 32° pitch
Style direction
Orientation: North/South, ridge line west/east
Maximum heights/limits: Max ridge height 7.50 m (24.6 ft)
Other requirements
Client requirements
Style, roof shape, building type
Basement, floors: Basement, 2 full floors
Number and age of occupants: 2 adults, 3 children (5, 3, 1)
Room needs, ground floor, upper floor: Ground floor: kitchen, dining area, living room, guest WC, guest room/office. Upper floor: master bedroom, 3 children’s rooms, 2 bathrooms
Office: Family use
Open kitchen, kitchen island
Number of dining seats: 8
Fireplace: yes
Balcony
Garage
Special features: bay window for dining area, upper floor: direct access to master bathroom from bedroom. Master bedroom facing garden, ideally 2 children’s rooms facing garden.
Origin of the design:
- Planner of a general contractor
- Do-it-yourself
Basically all requirements are met; only the room proportions could be improved.
What do you dislike? Why?
Currently, there is a large open space between living and dining that is not used effectively.
Due to the current staircase layout and resulting passage to the living room, the TV area in the living room is somewhat narrow. Ideally, it should be about 4 m (13 ft) wide.
On the upper floor, access to the master bath is via a small corridor behind the stairs. Ideally, this “dead space” could be eliminated by a different staircase shape or positioning.
Price estimate according to architect/planner: approximately 560,000 (excluding land)
Personal price limit for the house, including fittings: 580,000
Preferred heating system: Gas condensing boiler
If you had to give up something, which details/extensions
-could you give up: 3 rooms facing the garden
-could you not give up: 2 bathrooms
Why has the design ended up like this? For example:
Design from planner adapted and further developed with our own ideas.
Basically, the requirements are met, but we do not yet find the room layouts ideal. The living room on the ground floor should be somewhat wider.
Is the staircase appropriate in shape and placement? Can the living room be wider and the unused space between rooms on the ground floor smaller?
Basement floor plan: four storage rooms, pantry, heating/utility room, shower, water manifold, stairs.
Ground floor plan: entrance vestibule, cloakroom, WC, room, living, kitchen, dining, prefabricated garage
Upper floor plan: 3 children’s rooms, bathroom, shower, anteroom, sleeping, balcony.
Site plan for the design: plot and road layout with WA1 and WA4, scale 1:500
kaho6747 Jan 2020 13:18
How wide is the plot? I see a setback on the right side of less than 3m (10 feet). Is that allowed?
Which one is your plot on the site plan?
Holson!
7 Jan 2020 13:20
the plot is 16 m (52.5 feet) wide, with a required setback of 2.5 m (8.2 feet) at the edges.
Manuel
kaho6747 Jan 2020 13:24
The plot is quite narrow. The garage is already annoyingly tight. Would it be an option for you to rotate the house (just the external dimensions)? The rooms would of course need to be adjusted.
How important is the dining bay / conservatory?
What are the dimensions of the staircase and the floor-to-ceiling height? Without numbers, it’s hard to make an assessment.
7 Jan 2020 13:27
kaho674 schrieb:
How wide is the plot? I see a setback of less than 3m (10 feet) on the right side. Is that allowed?
2.50m (8 feet) was mentioned.
I would be interested in seeing the original floor plans. Is the staircase positioned like that there as well?
And the bay window? Does it have to be like that?
And why the square shape?
Is it the 4667? What are the dimensions of the building envelope / building plot?
11ant7 Jan 2020 16:10
Who suggested the idea or request for a gable roof with a knee wall of 1.80 m (5 ft 11 in)? Overall, the design looks to me like a basic model from forty years ago, only adapted in details to fit modern tastes. In other words, as a renovation, I would consider it successful, but I would not build it like this from scratch. I recommend reengineering the design.
