ᐅ Fewer operable windows with mechanical ventilation with heat recovery
Created on: 7 Jan 2020 08:05
Smarti99
Would you partially forgo openable windows in a new build with controlled residential ventilation? More fixed panes or only casement windows instead of tilt windows?
Manual ventilation is no longer desired then.
We made the mistake of installing two fixed floor-to-ceiling window panels in the living/dining room.
All our glass surfaces (except the fixed panel next to the front door on the north side) have roller shutters.
The two fixed panels are really dirty from all the construction dust in the new development area. On one of them, a few insects had settled while the shutter was rolled up. Now their crushed remains are stuck on the inside. This means you sit at the dining table in the evening and can comfortably look at the squashed insect carcasses...
Fixed panel without roller shutter: yes
With roller shutter: never again...
And the two fixed panels are really dirty from all the construction dust in the new development area. One of them even had some insects stuck to it when the shutter was rolled up. Now they are trapped on the inside. That means you sit at the dining table in the evening and get to enjoy looking at the crushed insect remains...
With roller shutter: never again... There are cleaning aids with magnets that allow you to clean the roller shutters simultaneously from inside and outside.
