Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201822 Dec 2019 06:35
The concrete is only ground and polished. Nothing is filled or skim-coated. An elastic joint is installed at the seams. It then resembles a shadow gap. In the living area, the concrete is impregnated, and in the garage, it is sealed with water glass. A few walls will be painted.
Tina mit K22 Dec 2019 09:00
Is the dust from concrete grinding just as fine and nasty as with plaster? After that, you almost want to go stand in a car wash.
Domski
22 Dec 2019 10:39
Are you sanding it in the traditional way with a drywall sander? If there’s nothing to fill with putty, you have to be extremely careful not to sand in any corners.
guckuck2
22 Dec 2019 10:41
The concrete/angle grinder can be seen in the picture.
Domski
22 Dec 2019 10:53
Wow. I just glanced briefly at the wall and skillfully ignored the black power cable lying on the floor.
guckuck2
22 Dec 2019 10:55
Domski schrieb:
Wow. I only glanced briefly at the wall and skillfully ignored the black boa constrictor on the floor.
So, not a giraffe, but an anaconda.
