ᐅ Photovoltaic system with supplementary storage heaters
Created on: 18 Dec 2019 20:10
bloodyscorpionB
bloodyscorpion18 Dec 2019 20:10Hello dear forum,
we have bought an older solid house.
The house is heated with night storage heaters and a tiled stove.
Is it worth installing a photovoltaic system with a storage battery? The roof faces southwest and has a dormer.
I look forward to your messages.
Phew… night storage heaters.
Basically: photovoltaic systems are always worthwhile if you can use a reasonable amount of the electricity yourself. Currently, a battery storage system is usually not economically viable.
With night storage heaters, the calculation might be different, but it depends specifically on the storage system’s lifespan, your self-supplied electricity during off-peak hours, and the size of the photovoltaic system. Additionally, to generate a significant amount of electricity for nighttime use, your photovoltaic system would need to be considerably larger than 10kW. This requires relatively expensive feed-in management, which reduces your profit margin again.
Example: With my 15kW photovoltaic system, I generated just under 8kWh of gross output today, and it was a fairly sunny day. In my KFW 55 house with about 170sqm (1830 sq ft) of living space, I had a heat demand of 18kWh from midnight until about 8:30 pm. This is heating demand only, measured via an uncalibrated heat meter on the heating circuit. The outdoor temperature was about 10°C (50°F) during the day and 2°C (36°F) at night. So even here, it doesn’t pay off.
The only really sensible way to use solar electricity for heating is with a heat pump, which stores heat in a buffer tank during the day when there is enough sunlight, operating with a coefficient of performance of 3 or higher.
Putting aside all theoretical calculations, I have serious concerns that the usage profile of a battery storage system does not align with the load profile of night storage heaters, which would massively shorten the battery’s lifespan.
hampshire18 Dec 2019 23:50When does the sun shine?
When do you need the heating?
Spot the mistake.
Spot the mistake.
Fortunately, a photovoltaic system purchased at a reasonable price is a profitable investment on its own, as long as you don’t ruin it by adding storage. Self-consumption is the cherry on top and helps achieve even faster payback. However, you can safely exclude winter from the calculation since very little sunlight reaches the roof then.
goalkeeper19 Dec 2019 07:50From a non-expert perspective, wouldn’t it make more sense to invest in a new heating system instead of a photovoltaic system?
hampshire19 Dec 2019 09:31goalkeeper schrieb:
Wouldn’t it make more sense from a non-expert perspective to invest in a new heating system instead of a photovoltaic system?If it is a liquidity-related "either-or" question, it can certainly be calculated once. If not: The investment in a photovoltaic system on almost every house makes sense – regardless of the heating system.
