ᐅ Underfloor heating with an air-to-water heat pump. House gets too warm when the sun is shining.
Created on: 4 Dec 2019 14:18
chewbacca123
I have a general question.
We moved into our new build four months ago. The living area on the ground floor has three large floor-to-ceiling windows facing south. We have underfloor heating and an air-to-water heat pump.
It provides a really comfortable temperature inside the house, but we have a problem – whenever the sun is shining in winter, even if it’s -2°C (28°F) outside, the temperature suddenly rises to 24°C (75°F) in the living room. It gets uncomfortably warm in here, and the underfloor heating can’t be turned down quickly.
Should we assume that the large floor-to-ceiling windows are responsible for the heat gain? A photo of the south-facing side of the house is attached.
What would you do – always lower all the blinds as soon as sunlight is forecast? That seems quite annoying...
We have motorized blinds controlled by Somfy. Would you consider buying a sensor that automatically lowers the blinds at a certain temperature?
Thanks in advance for your replies.
Bookstar schrieb:
My end point is 28 degrees, which is enough.Return flow, yes. Supply flow would be quite optimistic. But we will only find out when it actually gets really cold.
Lumpi_LE schrieb:
The heating curve looks quite normal, it’s very strange that it’s showing you any supply temperatures of 65°C (149°F)... I just discovered this:
Bookstar schrieb:
My endpoint is 28 degrees, which is sufficient.I just found this, which is probably the actual value:30.9°C (88°F) at an outside temperature of 3°C (37°F) is far too high. The return temperature is only 0.2 K below the supply temperature, meaning the heating energy remains in the water. Most likely, all ERRs are closed?!
I would recommend having the system inspected. Nothing is working properly.
