ᐅ Fence height adjacent to the neighbor and windows in the boundary wall
Created on: 28 Nov 2019 09:58
Climbee
Our dear neighbors… I’ve mentioned this a few times before.
But anyway: both of us (including the neighbors) want a privacy fence between our properties. So far, we had planned to have a landscape gardener propose a garden design, including this privacy fence, and then coordinate it with the neighbors.
A lot has changed since then, and we no longer plan to coordinate; we want to install the tallest possible fence.
As far as I know, I can put up a fence up to 1.80 meters (5 feet 11 inches) high without additional permission.
My question is: from which ground level is this measured? We have a slightly sloped plot, and on the side where the privacy fence is planned, we will not raise the terrain but will extend the terrace into a balcony. So, there will be no retaining wall underneath, just support columns on which this “quasi” balcony will rest.
The height difference to the neighbor’s property should be about 100–110 centimeters (39–43 inches) at the highest point.
Am I allowed to measure the 1.80 meters (5 feet 11 inches) from my (higher) level, or is the natural ground level decisive?
The building permit originally included a retaining wall at this spot, which, as mentioned above, has now been replaced by support columns (this is the current planning stage; if we need a wall to reach the 1.80-meter (5 feet 11 inches) privacy height, we will build one).
Second pain point:
The neighbor’s garage is built on our boundary line, and in the boundary wall there is a window facing our property, which was neither approved nor registered in the land register. This is a standard wooden window that opens. At one time, there were shutters installed that extended onto our property, but now only the brackets remain, which still protrude about 15 centimeters (6 inches) onto our land.
As far as I know, this kind of window should generally meet fire resistance class F90—but I don’t really care; that’s for their fire insurance to sort out.
The protruding shutter brackets bother us because you can catch on them—they’re simply in the way. Also, after a few incidents, we would prefer that this window cannot be opened and that the neighbors can’t look into our yard there (we actually want to create our main terrace in that area).
If the neighborhood were friendly, I wouldn’t mind at all, but here…
In Bavaria, there is a so-called window protection law (Art. 43–45 AGBGB):
Windows and any kind of light openings that are less than 60 centimeters (24 inches) from the property boundary must, at the neighbor’s request, be designed so that up to a height of 1.80 meters (5 feet 11 inches) above the floor level of the lit room (approximately eye level) neither opening nor looking through is possible. When using opaque glass blocks, no impairment to the neighboring property is expected; therefore, exterior walls with such light openings are permitted within the 60-centimeter (24-inch) protection zone.
I also found this:
A peculiarity of the Bavarian regulation is that it depends on the use of the neighboring property. For the owner to invoke the window protection law, their property must be either developed or used as a courtyard or garden. If a previously undeveloped property is later built on, from that point onward the window protection law can be enforced, meaning windows that are located within the boundary distance in exterior walls on the adjacent property must be modified as required by Art. 43 AGBGB at the neighbor’s request.
Does this mean I can demand that the window be modified accordingly?
Can I also plan something in front of the window? The wall looks awful, and as part of the garden design, we will definitely do something there. It won’t come down to me repainting the neighbor’s wall every two years (he unfortunately installed bargeboards on the boundary side with no gutter, so water drips onto the wall causing stains—no matter if we paint it, it will look bad again after two years). To what extent do I have to consider the window? Or could I just put up a wooden fence in front of it?
What can be done about the really obstructive brackets? Are we allowed to simply remove them, or do I have to request the neighbor to do so?
Here is a picture (from long ago – instead of the little trees, our garden furniture is now there *g*), so you can get an idea:
Weiße Hauswand mit kleinem Holzfenster im orange-gelben Rahmen; Baumzweige davor.
If you look closely, you can see the brackets (we will just leave the fact that the windowsill also protrudes onto our property as it is).
We’re currently planning the garden, so these questions are very urgent right now.
Climbee2 Dec 2019 16:05
Hmm... I think I’ll ask our architect about this (he actually sealed off his neighbor’s unauthorized windows in the boundary wall without permission) and, if necessary, consult a lawyer knowledgeable in neighborhood and building law to find out what is actually approved. That’s one thing.
The other question concerns the technical execution. How do I properly build a wall there? There must be some kind of sealing against the existing structure, right?
Tassimat
2 Dec 2019 16:07
Maybe a high wooden wall would require less effort?
Domski
2 Dec 2019 20:28
First, check whether you are even allowed to build anything there: key term is building boundary according to the development plan, if one exists.
Then look into the state building code to see what you can construct within the setback area without needing a permit: key term is privileged buildings. Here in Hesse, for example, this includes waste sheds, garages, heating and energy supply installations, dog houses, or woodpiles. No walls!
Walls are often regulated separately; here in Hesse, walls up to 1.5 meters (5 feet) in height can be built without a permit.
Finally, consult the development plan again regarding enclosures: here, enclosures are only allowed up to 1.5 meters (5 feet) in height and must be camouflaged on both sides with hedges.
So, I wouldn’t be allowed to brick up the windows here. The most you could do would be a freestanding firewood stack. However, its dimensions are also limited...
2 Dec 2019 20:48
Climbee schrieb:
As I said: like a garage wall, just without the garage.
@Scout is probably right there. Walls are not buildings.
And privacy fences must be installed with the appropriate spacing (height/distance).
How big is the window? I would plant a tree in front of it.
Scout
2 Dec 2019 21:53
Yes. About the size of a *F***ktus*:
Large Saguaro cactus with several arms in front of blue sky and rocks in the background.
*duckandrun*
E
Escroda
2 Dec 2019 22:28
Climbee schrieb:
There has to be some kind of sealing to the existing building, right?
Yes. In Bavaria, they are very conservative with their neighbor law. Here, it is clearly stated in the legal text (Neighbor Law NRW):
§ 22 Construction of a second party wall
(1) If a building is constructed directly on the boundary line on one property, and later a building is erected on the neighboring property along the same boundary line but without a structural connection, the builder of the latter is obliged to close the gap that arises at their own expense in a proper manner to prevent damage in the gap area, especially due to building movements and weather exposure, to the first constructed building. The necessary connections must be adapted in terms of the materials used to the existing building.
Domski schrieb:
No walls!
HBO §6 paragraph 10 (exemptions)
6. Fences, privacy screens, and terrace partition walls in commercial and industrial areas, and outside these building zones, up to 2 m (6 ft 7 in) above ground level, ...
Domski schrieb:
Here in Hesse, no permit required up to 1.5 m (5 ft) height
Appendix to §63
Building permit-exempt projects according to § 63
7.1 Fences, terrace partition walls, and privacy screens up to 2 m (6 ft 7 in) in height ...
For Bavaria, I already mentioned the regulations in #2.
If the window is illegal, there is nothing standing in the way of a wall.
