Hi,
I need some advice. In our house (3 years old, solid construction, 36.5cm (14 inches) Poroton blocks), there is mold forming in one room at the corner where two walls (both exterior walls) and the ceiling (upper floor under the flat roof) meet. There is no mold anywhere else in the house, and we ventilate the room daily.
I had the roofer check the site, and they removed the roof down to the concrete layer, but everything is dry there.
Now we’re really stuck... Everyone is puzzled. What could be causing this problem?
Thank you and best regards
Mottenhausen26 Nov 2019 21:51It needs to be repainted anyway because of the stains, so take the opportunity to insulate the two exterior walls beforehand with gypsum board and expanded polystyrene composite panels, then fill and finally paint. The additional insulation will reliably solve the problem once and for all.
nordanney26 Nov 2019 23:30Mottenhausen schrieb:
insulate the 2 exterior walls with gypsum plasterboard and polystyrene composite panels,a: wrong material b: the entire wall? Why?
