ᐅ Flooring for a Double Garage – Screed with Two-Component Coating? Epoxy Resin
Created on: 18 Oct 2019 18:25
Kevinius
Kevinius18 Oct 2019 18:25
I am considering having fiber-reinforced screed with a slope installed in the garage. On top of that, a two-component epoxy resin coating—that would actually be my ideal solution.
What are your experiences with epoxy resin coatings? How durable are they?
How does the material hold up if a tool or part is dropped on it? Can it be repaired easily?
We have a raw concrete slab that is 15cm (6 inches) thick.
The area is approximately 70m² (750 square feet).
Regards
Bookstar
18 Oct 2019 22:15
You can forget it; it won’t last permanently. Have a professional apply the coating with 5 work steps, 2 to 3cm (about 1 inch) thick. It will last 100 years. You can skip the screed; a concrete floor is sufficient.
Michlhausbauaa
19 Oct 2019 16:18
Bookstar schrieb:
You can forget it, it won’t last permanently. Get a professional coating done, with 5 work steps, 2 to 3cm (around 1 inch) thick. It lasts 100 years. You can then skip the screed; a concrete floor is enough.
What exactly is that?
Bookstar
19 Oct 2019 18:11
The floor is sanded, gaps are filled with resin, then sanded again, primed, coated with a two-component compound, optionally sprinkled with material for grip and appearance, followed by a final layer of paint.
Kevinius20 Oct 2019 09:57
And who offers something like this? How much does it cost?
What is the alternative if you don’t want tiles?
rick201820 Oct 2019 12:03
There are quite a few options. Concrete with water glass, two-component epoxy (as explained by Bookstar), stone carpet, cast asphalt... There are specialized trades for each of these. You can find them quite easily through Google or by consulting the architect.
