krischaaan17 Oct 2019 21:26Hello everyone,
Our plot has a slight slope that we would like to level out with a wall...
The wall will be approximately 12 m (40 feet) long and 20–50 cm (8–20 inches) high.
Is it possible to build this without a concrete footing? Just with crushed stone?
What should I pay attention to? Specific types of stones?
Adhesive?
Moisture barrier?
Drainage membrane?
There is lawn on one side, and the other side is open ground.
Any other tips?
Thanks! Good luck
Adhesive?
Moisture barrier?
Drainage membrane?
Any other tips?
Thanks! Good luck
HilfeHilfe17 Oct 2019 21:38Excavate about 40 cm (16 inches), add 10 cm (4 inches) of gravel, then 20 cm (8 inches) of cement before placing the stones.
hampshire17 Oct 2019 22:54Drainage on the hillside is important. You can also lean a wall against the slope without a concrete foundation. Massive stones work as well.
We recently completed building a wall like this ourselves, without a concrete footing. It is two formwork blocks high. We placed a thick layer of gravel underneath and compacted it. We set the formwork blocks firmly in concrete screed (coarse mix), inserted reinforcement steel, and then filled it with the same concrete screed. The first half of the wall was built a year ago and has stood without any settling since then.
guckuck2 schrieb:
Why is there still a connection pillar standing there?!It’s probably required by regulations in our federal state...
