ᐅ 200 m² single-family house for 4-5 people without a basement on a narrow lot
Created on: 7 Sep 2019 18:07
hausbauer
I’m looking forward to your opinions on this design.
Thanks in advance for your suggestions!
Plot size 525 m² (5650 sq ft), 17 m (56 ft) narrow along the street at the south end x 31 m (102 ft) long north-south orientation
Land is completely flat
Site coverage ratio 0.4
Floor area ratio 0.8
Building envelope, building line and boundary each 5 m (16 ft) from the street at the south and from the northern border
Edge development
Number of parking spaces 2
Maximum height / limits 8 m (26 ft) total height (attic will be quite low)
Number of people, age 2 adults + 2 children (currently small) + possibly a third child
Room requirements on ground and upper floor 2 children’s rooms, 1 office/guest room large enough to be another children’s room, 1 additional small office, guest bathroom with shower, open living-dining area
Office: family use or home office? Only for work after hours and weekends, as well as for taxes etc.
Number of overnight guests per year few
Open or closed architecture
Balcony, roof terrace no
Garage, carport Double garage would be good, but probably won’t fit?
Utility garden, greenhouse no
Other wishes / special features / daily routine, also reasons why some things should or shouldn’t be included
Bedroom facing north for a clear view; no north-facing garden because it would be too dark in autumn/winter due to shading from surrounding houses; overall, lots of natural light in the living areas is very important to us
Enough usable space and storage inside the house (large utility and service room), since we don’t have a basement and there is no room on the plot for large garden sheds
Who designed it: self-designed based on a template
What do you like most? Why? Layout of the upper floor (nice children’s rooms with south and southwest orientation, bedroom facing north, large utility room), possibility of a second terrace on the north side by the guest room for shade and view north in midsummer
What do you not like? Why? Entrance area on the ground floor is a bit narrow, otherwise we’re quite inexperienced with what might work well or not in everyday life.
If you had to compromise, on which details or expansions
-You could do without: large hallway areas, if necessary a half-landing staircase (instead of more space-consuming stairs), if needed a pantry next to the kitchen (could be replaced by space under the stairs), a structural requirement might mean adding an extra partition wall in the utility room (which could also be used as a room divider for more storage space)
-You cannot do without: south-facing living-dining area, enough space for bicycles etc. on the property (currently a bit tight)
Questions about the floor plan:
- Is the plot well used?
- Is the entrance area too narrow at 175 cm (69 inches)?
- Are the rooms arranged practically for a family of 4 to 5?
- Do we have enough storage given that we lack a basement and the attic is quite low?
- Is it a big disadvantage in terms of sound transmission that the two children’s rooms share a common wall?
Note: The entire plan will be revised by a professional once we are happy with the overall layout. Then dimensions will be more precise, drawings nicer, and structural calculations reliable. I’m just interested in early feedback on potential weak points and good alternatives.
Edge development
hausbauer7 Sep 2019 20:57haydee schrieb:
Replacing the small storage room with a built-in closetThis will be difficult because the wall facing the bedroom is probably load-bearing. However, someone with structural engineering knowledge should be consulted.H
hausbauer7 Sep 2019 21:08Hmm... the storage room on the upper floor seems unnecessary if the utility room is located there.
I don't like the bedroom. Or rather, it depends on what is planned for the walk-in closet.
And where is the bed supposed to be placed? In front of a window?
I think 3.60 x 3.70 meters (11.8 x 12.1 feet) is possibly too small for a living room for up to 5 people.
Putting aside the interior layout, I would place the house all the way forward at the 5 m (16 ft) line to avoid disturbing the garden. If I wanted a sunny seating area, I would create it separately at the back in the garden.
This also has the advantage of cheaper utility connections.
If your shed is 310 cm (122 inches) wide, then the garage won’t fit.
The garage would have a maximum exterior width of 250 cm (98 inches), meaning a maximum interior width of 215 cm (85 inches), which is too small for any car.
Either one of the measurements is incorrect, or the positioning on the plot is wrong.
17 m (56 feet) width - 310 cm (122 inches) right boundary construction - 930 cm (308 inches) house width = 460 cm (181 inches) remaining width … visually, there should be more green space on the left than the strip on the right side of the house.
A full site plan would also be helpful, including visible neighboring plots, etc. South-facing terraces are not always ideal; east, west, or northwest-facing terraces are often better. Sunlight should come from the south, especially in winter.
For evaluation, it’s always useful to present house floor plans together with your furniture ideas because only then can you truly judge whether the plans work. For example, I consider 360 cm (142 inches) in the living area quite sufficient, depending on the TV size. The viewing distance no longer needs to be as long as it was with the old CRT TVs.
It’s also important to know the planned windows’ sill height … having a sofa in front of floor-to-ceiling windows is usually not very practical.
hausbauer7 Sep 2019 22:54Thank you for the honest feedback, please be critical. It really helps to reconsider decisions already made before making them final.
What’s important to me about the orientation of the house is to get at least some sunshine on the terrace and in the living area even in November, when the sun does shine. Due to surrounding buildings, this is usually difficult during the darker half of the year because of long shadows. We debated a lot about having a north-facing garden or a south-facing garden, but having a few hours of sun on the terrace throughout the year was quite important to us. I’m not sure if this compromise is the right one. In May, June, and July, the north-facing garden is probably nicer because the sun comes around from the side, but what about the rest of the year?
(Houses not drawn to scale)
Very observant, in the original measured sketch I had still hoped to use half the building height as the clearance distance for the shed. However, it has now become clear that I can only build the shed as a boundary structure with a length of 3 m (10 feet), since the garage on the same boundary is already 6 m (20 feet) long, and the maximum length allowed per side is 9 m (30 feet). So the shed now measures 4.25 x 3 m (14 x 10 feet) in the colored sketch. That is, if it stays at that location...
kbt09 schrieb:
If your shed is 310 cm (10 feet 2 inches) wide, then the garage won’t fit.
