ᐅ Alternative to Proxon air-to-air heat pump?
Created on: 12 Aug 2019 16:21
NiciHoh
NiciHoh
12 Aug 2019 16:21
After a long search for a construction company, I decided on Galileo-Home, who will be building my bungalow.
Over the past weeks and months, I have repeatedly come across the air-to-air heat pump from Proxon, and I really like this system because I’m not a fan of slow and overly warm underfloor heating.
My only problem is that Zimmermann, the company that sells and installs Proxon systems, does not collaborate with Galileo-Home and does not want to install such a system for me.
Now to my question:
Are there comparable alternatives to the Proxon system? A solution with similar fresh water heating would also be interesting, of course.
Unfortunately, after intensive research, I haven’t found anything concrete and would appreciate any tips.
Nicolas
KingSong12 Aug 2019 19:54
A modern underfloor heating system will never become excessively warm. In normal use, you won’t even notice that you have underfloor heating. From an energy perspective, your chosen air-to-air heat pump consumes a lot of electricity; air is the least efficient medium for heat transfer. It is inexpensive to install but costly to operate.
boxandroof
12 Aug 2019 20:51
You have now been informed about the technical aspects. For the manufacturer, try using your favorite search engine or the search function here in the forum.
Regarding your question: @haydee here in the forum has an air-to-air heat pump in her passive house from a manufacturer who apparently takes the planning process fairly seriously. Consumption data is not yet available. Outside of a passive house, I would not consider air-to-air systems.
The better you plan the underfloor heating, the lower its temperature can be, and the more efficiently the heat pump will operate.
lesmue79
12 Aug 2019 22:18
Try working with a system partner or your regular heating installer who is familiar with Meine products, as they also offer exhaust air heat pumps. However, outside of a passive house, these units are generally not very suitable.
Z
Zaba12
13 Aug 2019 07:27
NiciHoh schrieb:
The company Zimmermann, which sells and installs Proxon systems, does not collaborate with Galileo Home and does not want to install such a system for me.
Then you were still lucky!
NiciHoh
13 Aug 2019 07:50
It seems that opinions are clearly against air-to-air systems, from what I’ve seen here. Thanks for that, first of all.
Okay, I could probably get used to underfloor heating. The only thing that might bother me is that it could be constantly too warm.
I currently live in a timber-framed house and I’m the type of person who always has the windows open. If I feel cold, I close the window, turn the radiator up a bit, and then it gets warm. Otherwise, my windows are always open, and I heat spontaneously and only when I need to. Most likely, a traditional radiator would still be the best choice for me, but who wants radiators in a modern new build?
I hope you can understand my issue and why I considered an air-to-air heat pump system.
