Created on: 27 May 2019 10:48
goalkeeper
goalkeeper
3 Aug 2019 09:15
kaho674 schrieb:
You can’t really use the topsoil for backfilling anyway.
I’d go for the basement. It’s practically already there. 2.40m (7 ft 10 in) strip foundations = ideal basement height. You can leave it unfinished at first. Then you only pay for the stairs, the floor, and the essential supporting columns, right? Have some empty conduits installed going down... If you suddenly come into some money, you’ll be happy; otherwise, it serves as storage space for relatively little additional cost.
We will have it calculated. However, that quickly adds another 30-40k, since we would also move our equipment from the attic (top floor) to the basement – but then the attic has to be finished to a higher standard, which causes additional expenses. We have planned a contingency, but not 60k, which is roughly the total cost of the basement with the extra work.
kaho6743 Aug 2019 09:24
goalkeeper schrieb:
However, that quickly adds up to an additional 30,000-40,000, since we would be moving our technical equipment from the attic to the basement – but the attic would then need to be finished to a higher standard, which causes further extra costs. We have included a buffer – but not 60,000, which is roughly what the basement with additional work will cost in total.
Moving the technical systems downstairs would be nice. But the attic wouldn’t get more expensive because of that, would it?! Unless you give up what I consider the unnecessary dormer and save the money for the additional slab.
goalkeeper
3 Aug 2019 09:48
kaho674 schrieb:
Putting the technical installations downstairs would be nice. But the attic doesn’t get more expensive because of that, right? Unless you skip the, in my opinion, unnecessary dormer and save the cost of the additional foundation slab.
Alternative roof windows also cost money – and the dormer costs only around $7,000, so the savings wouldn’t be significant.
We could remove the mechanical ventilation system – that costs about $15,000. Then we would save some money.
kaho6743 Aug 2019 11:09
Removing the dormer and the controlled residential ventilation system basically turns it into almost a basement.
You can’t really calculate the costs the same way as at the beginning. Basically, you HAVE to build the basement. The money for the walls and the structural support is gone either way. Filling it with gravel now to avoid electrical outlets is almost silly. Yes, okay, you still need a staircase—but it doesn’t have to be a fancy one like the others. A foundation slab or a floor above will be added. Okay, that also needs to be paid for. Other than that, I don’t see any major extra expenses. No one is forcing you to lay tiles down there, to build walls, or to install a lighting system. And if you want, you can do those things later.
goalkeeper
3 Aug 2019 15:03
kaho674 schrieb:
Dormer gone and mechanical ventilation removed – it’s almost like a basement now.
You can’t really calculate the costs like at the beginning anymore. Basically, you HAVE to build the basement. The money spent on the walls and structural engineering is already gone anyway. Filling it with gravel now so you don’t need electrical outlets is almost ridiculous. Sure, you still need a staircase – but it doesn’t have to be a luxurious one like the others. A slab or a ceiling will be added. Okay, that also has to be paid for. Otherwise, I don’t see any major additional expenses now. No one is forcing you to install tiles, put up walls, or set up a lighting system down there. And if you get the chance, you can always do those things later.
If only it were always as simple as you describe...
goalkeeper
7 Aug 2019 11:33
kaho674 schrieb:
Removing the dormer and controlled residential ventilation – it’s almost like having a basement.
You can’t really calculate the same way you did at the beginning. Basically, YOU HAVE to build the basement. The money for the walls and structural engineering is lost anyway. Filling it with gravel now just so you don’t need electrical outlets is almost foolish. Yes, okay, you still need stairs – but they don’t have to be as extravagant as the others. There’s also the slab or ceiling to consider, which also needs to be paid for. Otherwise, I don’t see any major additional costs. No one is forcing you to install tiles, build walls, or set up lighting down there. And if it suits you, you can always do those things later.
To revisit your idea of a stripped-down basement: what can actually be left out if the basement is used solely for storage and as a utility room?
Do I absolutely need a screed and underfloor heating? Is it necessary to construct interior walls? How does this comply with energy-saving regulations? Wouldn’t the basement’s cold then rise to the upper floors on cold days?
What are your thoughts?
