ᐅ Which type of filler or joint compound should be used?
Created on: 3 Jul 2019 11:50
Reini1234
We need to get joint compound for our painter now. The base materials are gypsum fiberboard walls and gypsum plasterboard ceilings.
He doesn’t have a strong brand preference, normally he uses Knauf UniFlott, which he says has inconsistent quality. In terms of application, he prefers Gima joint filler. There is also Rigips Vario, which can be used without reinforcement tape, and Rigips Super joint filler, which requires reinforcement tape. There is, of course, a price difference:
Knauf 33 EUR
Gima 32 EUR
Vario 38 EUR
Super 22 EUR per 25 kg (55 lb) bag
Are there any significant quality differences here? In another forum, I read that one should look for a fiber-reinforced product to help prevent cracking. Any opinions?
Nafranky
7 Jul 2019 21:14
Ardex 828 is very easy to work with. It can be applied without the need for reinforcing mesh.
Grantlhaua
10 Jul 2019 14:12
Can be applied without mesh tape
That would have been my recommendation too. I'm currently using it for concrete ceilings/walls. It sets very quickly, so only mix as much as you can apply within about 15 minutes.
Nafranky
10 Jul 2019 20:00
Grantlhaua schrieb:
That would have been my suggestion as well. I'm currently using it for concrete ceilings/walls. It sets very quickly, so only mix as much as you can work within about 15 minutes.
Follow the curing time, then it works!
Or you can also get it premixed in a bucket!
